Old 03-21-2006, 12:50 PM   #1
rayne's Avatar
Year: 1985
Chassis: IHC
Engine: 9.0
Rated Cap: 76
cat motors
does any body know any thing about a cat 3408 motor I've got one in my 75 ihc and was just wondering what quality it was compared to a detroit or cummins etc....
not all who wander are lost
rayne is offline   Reply With Quote
Old 03-21-2006, 01:11 PM   #2
rayne's Avatar
Year: 1985
Chassis: IHC
Engine: 9.0
Rated Cap: 76
auto to manual
also my bus has an auto trans and I would like to convert it to manual...........any tips, been searching high and low for some kind of repair book to no avail
peace
Old 03-21-2006, 03:40 PM   #3
vonslatt's Avatar
Sure it's a 3408 and not a 3208 ? A quick google tells me the 3408 is a 4-500 hp over the road truck engine, if you've got one in a Skoolie that would really rock.
I've got a 3208 NA with 210 hp, it has a rep as a really solid motor, it's kind of dirty though which is why it is very rarely found in buses newer then 1989.
My 1989 Thomas Saf-T-Liner
vonslatt is offline   Reply With Quote
Old 03-21-2006, 03:46 PM   #4
frank-id's Avatar
Kitty engines
Most buses, because of the initial cost, use a small "Cat" engine know as a 3208. This is what is called a car engine in as much as, the HP is limited and the engine does not have sleeves. Most of these engines are limited to 210HP... This engine is a v-8. The bad boy Cats are usually in line 6 cylinders. There is a real nice Cat engine called a 3406, and this bad boy makes about 350HP....
I would very strongly advise not to change the auto trans for a manual. The auto trans is a great unit and will last a very long time. But if ya want to do the deed, I want an Allison and will do some trading. I have a few 5 speeds and a 10 speed. I di not have any clutch parts or linkages. Frank
Old 03-21-2006, 06:01 PM   #5
lapeer20m's Avatar
.....i'd use a hydraulic clutch pedal instead of actual linkage......
if i ever get a bus i don't plan to sell, i'd like a 10 or 13 speed trans. but i think the auto helps with resale value.
Old 03-22-2006, 07:55 PM   #6
rayne's Avatar
Year: 1985
Chassis: IHC
Engine: 9.0
Rated Cap: 76
right on
yeah ..right after I posted I went and looked at it ....3208
does anbody think I should change it out for more hp?
Old 03-22-2006, 08:53 PM   #7
Coachwork: Ward Genesis
Engine: DT466/MT643
Keep it...not a bad engine, though kind of smokey. Just don't ether it! My uncle's hauler has a 3208 turbo, and it had seven broken rings thanks to someone getting ether-happy.
IP timing is hard to get right...it'll run funny if it's off. A real Cat guy can get it. If you need this done, go to a Cat shop & ask to talk to the oldest guy there.
Jarlaxle
Old 03-27-2006, 11:21 AM   #8
rayne's Avatar
Year: 1985
Chassis: IHC
Engine: 9.0
Rated Cap: 76
what about the added weight? once done I'll have added about 8000- 10000 lbs
Old 03-27-2006, 12:35 PM   #9
lapeer20m's Avatar
that's not enough weight to gain any real advantage. Fuel economy is not significantly affected by a couple thousand pounds. In both of my buses i get about the same mileage with the 400 gallon jacuzzi full or empty.
BB-under seat heater motors opus Classifieds | Buy, Sell, Swap 5 11-18-2010 07:55 AM
need air wiper motors for 82 Crown bus paul iossi Classifieds | Buy, Sell, Swap 2 05-16-2009 09:12 AM
what motors came in this bus? 68fordb600 Mechanical and Drivetrains 5 12-02-2008 08:30 PM
wiper motors timbuk Conversion General Discussions 9 10-18-2008 08:39 PM
blower motors abdabbs Conversion General Discussions 5 03-26-2007 12:00 PM
