Old 03-09-2004, 10:41 PM   #1
batchlor BusMan's Avatar
Send a message via AIM to batchlor BusMan
cheap power inverters
there selling COBRA 2000 watt continous/ 4000 watt peak for $130 on ebay right now. The cobra website shows them going for $550. There is auctions where you can get them cheaper if your lucky or just use the buy now button for 130 bucks.
Even a blind squirrel finds a nut every once in awhile.
batchlor BusMan is offline   Reply With Quote
Old 03-10-2004, 08:33 AM   #2
lapeer20m's Avatar
CHEAP inverters are the only way to go. I'm not familiar with the cobra brand, but i'm sure they're equal to other cheap inverters. I had a 2000/4000 peak coleman that was under 200 bucks. I currently use a pair of 775 watt inverters instead.
All of these "cheap" inverters create what's knows as dirty power. It's not the same power you have in an outlet inside your house. These inverters create what is officially known as a modified sin wave. Some devices won't work on this modified sin wave. Laser printers, some dvd players, transformers for X-10 camera's, are a few of the things i've found that won't work off of dirty power. Most devices are fine. Any incandescant light will work fine. Most devices that utilize transformers are ok (most devices that don't make heat or light use a transformer) Anything that makes heat will consume a lot of energy, and therefore be difficult to run with an inverter, but the heating element will work just fine with a modified sin wave. Most electric motors will also run just fine, but again can have a significant amperage draw.
The amperage of a 120 volt device needs to be multiplied by a factor of 10 to approximate the amps being drawn from the 12 v battery. For instance, if you have a frige that uses 120 volts, 7 amps. The batteries have to supply at least 70 amps of 12 volt current + the 10% or greater loss the inverter makes in the process of modifing the current. It takes a lot of 12 volt power to continously run any large device.
Tv's , computers, vcr, ect take very little power. My 25 inch tv takes approx 1 amp at 120 volts.
To answer you question......buy the 2000w inverter, you'll be happy with it. Just remember it's not magic, and if you're going to be using it without the bus engine running, you'll need a bank of batteries separate from the starting battery......Batteries are a whole new can of worms............
hope this helps more than it confuses.
Old 04-06-2004, 06:02 PM   #3
Send a message via Yahoo to capttrips25
I run my TV and DVD player while Im on the road using a Wal Mart MaxxSST 350-Watt Power Inverter and it does just fine. It cost under 50 bucks. I use the 5000 watt Craftsman gas generator to run the micowave and Air conditioning and use it to run everything while Im parked.
Sans Puer!!!
capttrips25 is offline   Reply With Quote
Power inverters and electrical questions MissJaneStrummor Conversion Tutorials and How-to's 1 04-16-2014 02:34 PM
Power inverters and their uses drchefscott Skoolie Conversion Projects 17 04-16-2009 09:46 AM
Harbor freight power inverters lapeer20m Conversion General Discussions 0 09-20-2007 11:15 PM
Cheap Power Inverters the_experience03 Conversion General Discussions 11 03-10-2006 08:18 PM
Power Inverters - which makes more sense? bus.driver Everything Else | General Skoolie Discussions 2 02-24-2004 12:01 PM
