Old 11-16-2019, 06:50 AM   #1
Year: 1985
Coachwork: Leyland
Chassis: Leyland
Engine: Cummins
Rated Cap: 17500, probably kg
Cleaning walls for spray foam
How clean should my walls be for good spray foam adhesion? Getting this stuff off is _really_ hard...
Attachment 39300Attachment 39301
Crisfole is offline   Reply With Quote
Old 11-16-2019, 07:02 AM   #2
Links aren't working.
Old 11-16-2019, 07:50 AM   #3
Year: 1985
Coachwork: Leyland
Chassis: Leyland
Engine: Cummins
Posted from Tapatalk.... One sec
Old 11-16-2019, 08:02 AM   #4
Year: 1985
Coachwork: Leyland
Chassis: Leyland
Engine: Cummins
Ok, I'll describe... Weird that the links work for me. Anyway:
The entire inter wall is covered in old adhesive and composite strips of wood used to keep buzzing down, I presume. It's all 35+ years old and very hard to get off...
Old 11-16-2019, 09:51 AM   #5
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
If its dry and not sticky or oily it should stick ok. You could get a cheap can of great stuff and do a test area. With a bus of that age you want to make sure the metal is not corroding behind the adhesive. I had lots of sticky black goo that I wasn't confident spray foam would stick to so I've removed it. It was a huge PITA but I know my spray foam will stick now.
Ted
Old 11-16-2019, 12:16 PM   #6
That foam pretty much sticks to everything. It sticks even better to everything you don't want it on.
Old 11-16-2019, 12:57 PM   #7
Year: 1985
Coachwork: Leyland
Chassis: Leyland
Engine: Cummins
Haha! The whole bus is Aluminum except one or two parts. Aluminum oxide isn't that damaging or spreading, happily!
I'll probably just chisel it off then wire brush it.
