Old 02-11-2018, 07:31 PM   #1
Concerns regarding humidity
Im trying to draw/write out and think about everything before i go at it. One of my more recent thoughts was the fact that florida is hot and humid. I imagine the tepmerature when i get into my car, this summer the CD cases in my car literally warped from the heat. So it could probibly get that way in a skoolie yes? I have plans for solar panals on top and about 8 batteries to hold a charge for night time and also having the option to plug in if available but is there somthing i could add that would keep it not blazing hot and humid when im not in, vent fans or a small low powered ac? Has anyone done this or enountered this problem?
Sent from my LGMP450 using Tapatalk
Rudy21 is offline   Reply With Quote
Old 02-11-2018, 07:57 PM   #2
Jdawgsfanasty's Avatar
Ice?
Jdawgsfanasty is offline   Reply With Quote
Old 02-11-2018, 08:00 PM   #3
Originally Posted by Jdawgsfanasty View Post
Ice?
Nope
Old 02-11-2018, 08:04 PM   #4
Nope
Idk...Montana b/t may and Sept?
Old 02-11-2018, 08:33 PM   #5
Robin97396's Avatar
There are times when my bus gets hotter than I can stand way up North here in Oregon. These are a metal box, and you know how hot a metal box can get in the summertime.
Discussions have been about using a raised skin, like on a landrover roof, to deflect heat. Shades, like the RVs have, or awnings they're called. That still won't do anything about that massive humidity. Wrong state for comfortable temps in the summertime. You won't like AZ either in the summer.
Robin
Nobody's Business
Old 02-11-2018, 09:06 PM   #6
Yeah florida isnt the most ideal place to be trying to live in a skoolie haha. Thanks for the input tho
Old 02-11-2018, 09:27 PM   #7
Have you considered pulling your ceiling panels and filling that 2" cavity with insulation?
Old 02-11-2018, 09:30 PM   #8
I really didnt want to have to mess with the cealing if i dont have to, not so much because i dont want to but from a budget aspect, i was thinking about coating the top of the bus with a thick rubber sealant (forget what its called) ive heard that helps a lot
Old 02-11-2018, 09:38 PM   #9
Chassis: Saf-T-Liner MVP ER
There isn't a cheap and easy way to do this if you want to even begin to stay warm in winter and cool in summer.
Bottom line is that either you do it right, or simply accept that it won't ever be the way you want it.
You can get the roof decently insulated and break the thermal bridges for a few hundred dollars (and a lot of work). In the context of a bus conversion, it's not one of the big ticket items.
Steve Bracken
Build Thread
Old 02-11-2018, 09:46 PM   #10
Your right this definetly wont be cheap in any aspect but i still want to try to be cost consious. I probibly should just insulate it
