Old 03-30-2011, 09:32 PM   #1
RevBill's Avatar
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
Conversions and Calculators
Just one site I find handy .. though maybe it would be useful to someone else ..
http://www.csgnetwork.com/
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
RevBill is offline   Reply With Quote
Old 04-09-2011, 09:21 AM   #2
RevBill's Avatar
Re: Conversions and Calculators
http://www.blocklayer.com/TankRectangularEng.aspx
.. want to know the volume of your tank and how much weight when loaded?? .. this one will get you pretty close .. and you can adjust the fill depth ..
.. and if you are using a dipstick, or need to use one, check out the little yellow box to the right, it will give you the increment measurements for gallons of fill ..
.. you can also find a calculator on that sight for cylinders .. in case you are one of the folks using plastic drums ...
.. good site for general construction calculators too .. site has imperial and metric calculators ..
New to conversions - Questions Seeria Conversion General Discussions 2 10-20-2009 08:48 PM
Best live-in bus conversions SeanF Skoolie Conversion Projects 1 06-07-2009 08:31 PM
Wheelchair accessible conversions auctioneer Everything Else | General Skoolie Discussions 6 01-23-2009 01:56 PM
Weird Conversions GoneCamping Conversion General Discussions 11 11-29-2007 07:40 PM
other conversions, starter project bvc2000 Skoolie Conversion Projects 6 05-11-2005 07:17 AM
