Old 06-23-2016, 10:45 AM   #1
Cool refrigerator
A little pricey. But it is dual voltage. $1395.00
TruckFridge Model: TF2600 - Designed to fit into custom installations
Old 06-23-2016, 12:13 PM   #2
turf's Avatar
i have a similar one in my bus. dual voltage 12/120 compressor fridge. mine is dometic/waeco brand.
dual voltage is a misnomer. its a 12v refrigerator with a converter block mounted on the back. mine is plugged in to both sources 24/7. but it only gets 120v juice when i turn on my generator. it doesnt run any better on 120 than it does on 12.
its been great so far, i wish mine were bigger. that one your showing looks to be a nice size. storing a frozen pizza is kinda of the size necessary to use, imo.
here's a link to mine:
DOMETIC CoolMatic CR Compressor Refrigerators | West Marine
mines senses battery voltage and will shut off at a certain voltage threshold, however, listening to it cycle gives you a sense of the battery as well. frequent cycling = low battery. late at night that bothers me.
my other complaint of it is the look. they're expensive, efficient, 12v compressor fridges. cool fridges right? well, the first thing my gf notices in another camper is their fridge, and says to me, "look honey, they got a nice one".
for what they do, they are quite unimpressive.
Turfmobile Build Thread
Old 06-23-2016, 05:13 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Pretty much what I figured.
For a lot less money you could go the other way, a small 120V refrigerator and a small modified sine wave inverter. They don't really draw many amps. I ran that way for years in a semi.
I had one of the 12v ones from truckfridge.com, it was a nice two door that they don't offer anymore, I think it lasted about 5 yrs before the compressor died.
Dick
Old 06-23-2016, 08:26 PM   #4
Carytowncat's Avatar
Hi,
I have a two battery bank with solar and keep wondering if it would power my mini fridge, or how much it would drain the batteries if i hook it up. i haven't tried yet and am guessing that's the best evidence if it will work. One problem is that i am in the city and mostly eat canned or dried foods at the bus, only thing i really miss is butter. If i want food food i just go out to eat. Sardines on rice crackers have become a delicacy
Old 06-24-2016, 08:44 AM   #5
Could you elaborate on" small modified sine wave inverter". The modified part.
Old 06-24-2016, 09:00 AM   #6
Chassis: AARE
There are basically two kinds of inverters "pure" and "modified". A pure inverter makes AC with a wave form that is just like the power company makes. A modified inverter makes AC with a wave form that is different and many things either don't work at all or work "not as good". When I drove a semi I ran my refrigerator, desk top computer and microwave all off of a modified. The only thing I noticed was the microwave was a bit down on power and the clock was wrong. I have read that refrigeraters might not be as efficient, but I never had a problem. My induction cooktop didn't like modified, it made a buzzing sound even when turned off.
There was a discussion a while back here.
http://www.skoolie.net/forums/f13/mo...idge-7665.html
Dick
Old 06-24-2016, 11:54 AM   #7
Chassis: Blue Bird
Engine: ISC 8.3
My rule of thumb is that if it doesn't say "pure sine!" all over the inverter and its packaging, then it's a modified sine type.
Old 06-24-2016, 09:31 PM   #8
joeblack5's Avatar
Year: 98
The 12/24/120 volt dometics are very nice. The moto design is more efficient then a standard 120 fridge. This fridge also has an external condenser. Most small 120 volt fridges have the condenser integrated in the side walls. The nice advantage of the domestic style is that you can add insulation to the sides and other surfaces reducing the power even further.
If you run of solar it is easy to use all the cooling capacity during the day to freeze water or cooling blocks. They will keep the fridge cool duringbthe night. That also reduces the noise.
The microwave power is directly related to the max peak voltage of the wave. A sine waves peak is higher then a modified or square wave inverter.
Later j
Old 06-24-2016, 09:37 PM   #9
joeblack5's Avatar
Year: 98
I forgot... The 12/24 fridges mainly use compressors from danfos. Bd series. Domestic.. Norcold..waeco.. Engel all the same compressor. Check flebay and craiglist. About $150_250. The much older style fridges use a linear compressor that is not as reliable and humms a lot.
A fancy style medical transport freezer uses a stirling cooler. Very efficient but high cost.
Later j
Old 06-25-2016, 09:38 AM   #10
I have played aeround with modified and pure sine wave inverters... slightly older electronics say from the late 90s - mid-late 2000s didnt like themn very well... laptops, phones, CD players, etc..
however since many car manufacturers are installing inverters in their cars now... and many use the cheap modified type.. and with plug-in cheap inverters everywhere at every truck stop.. target store, etc.. the electronics manufacturers got smart and started making their stuff work with modified as to help eliminate customer calls and complaints...
that said i bought a GoPower pure sine wave 1500 just because to me its woerth it to have clean-power for my mobile DEV lab...
ifyou want to test vaerious small electronics.. go buy a cheapier walmaert inverter, polug it in your car cigarette lighter and play... you asrent out much if nothing works right...
