Old 01-09-2007, 07:53 AM   #1
Correct Oil Pressure
Does anyone know what the correct oil pressure should be for a 1978 International 345?
Thanks
cooter is offline   Reply With Quote
Old 01-09-2007, 09:14 AM   #2
Steve's Avatar
I think my '72 345 runs around 40 psi
Old 01-09-2007, 09:35 AM   #3
Upon startup mine runs about 75 to 80. after the engine warms up it drops to about 45 or 50. this is at idle.
when driving it goes bact to 70 75.
Old 01-09-2007, 09:42 AM   #4
Steve's Avatar
I run 10w30 in mine, are you running something more viscous?
Old 01-09-2007, 10:28 AM   #5
not sure what is in it.
I just bought it about three weeks ago and have not changed the oil.
I am working on the electrical system right now.
i was thinking i would probably put 5w30 in it.
Old 01-09-2007, 12:48 PM   #6
the_experience03's Avatar
That kind of pressure isn't out of the realm of possibility, but it might be worthwhile doing a secondary check on it. It's not uncommon foir sending units or the gauges themselves to get knocked out of whack. If you actually have that much oil pressure, congrats.
Old 01-09-2007, 01:10 PM   #7
I thought the gauge was out, so i replaced the electronic gauge with a mech. one and i get the same results.
If that high is good, then OK, I'm just not used to seeing that high of pressure.
Tire Pressure? TygerCub Conversion General Discussions 20 07-19-2012 07:11 PM
Selecting the correct alternator?? Any opinions? telluriders Alternative Fuels | Electric, Propane, Wood Gasification, etc. 26 03-01-2012 09:35 AM
pressure tank cheezypsnookle Conversion General Discussions 6 04-17-2010 09:52 PM
Air pressure to the gas pedal WHISPERS Conversion General Discussions 7 11-12-2008 09:52 PM
Tire Pressure gealto Everything Else | General Skoolie Discussions 4 09-12-2004 04:42 PM
