Old 06-16-2015, 08:23 PM   #1
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Crazy Chit That Goes Thru My Head When I'm Drinking
So wife & I are sitting on the porch having our 2nd glass of wine looking at & discussing the Bus. I get this idea of possiblly installing an intercooler, so i'm thinking I could pipe it out & mount it on the roof between my two stacks OR I could build a fiberglass box mount it where my muffler used to be install the intercooler there & on the days we're traveling all day I could fill the box with water & dry ice.
Are any of these a good idea OR should I stop drinking??
Old 06-16-2015, 08:30 PM   #2
RHOMBUS's Avatar
Chassis: Freightliner HDX
Engine: CAT 3126B250
I'd say drink more. I get my fair share of eyerolls trying to work out some "outside-the-box" ideas.
RHOMBUS is offline   Reply With Quote
Old 06-16-2015, 08:57 PM   #3
Engine: 190hp 5.9 Cummins
I say yes to mounting a small inter cooler up there.
Or keep it simple.
Old 06-16-2015, 09:48 PM   #4
I say do it.....
you can name it Scuba Bus
Old 06-16-2015, 10:09 PM   #5
Theoryredacly ???? I should be able to transverse 11.5 ft of water right now
Old 06-16-2015, 10:14 PM   #6
but your nose is underwater at 9'
Old 06-16-2015, 10:15 PM   #7
Absolutely add the intercooler. Makes a world of difference.
Oh yeah...and go ahead and have more wine too.
Old 06-17-2015, 07:07 PM   #8
Looking at intercoolers on ebay they don't list the port size, are they pretty much standard?
Old 06-18-2015, 12:50 AM   #9
How big you looking for?
You should be able to get one from a split rad international fairly cheap.
Nice and sort, not too tall.
Old 06-18-2015, 10:12 AM   #10
in for the post count
Old 06-18-2015, 10:25 AM   #11
Intercoolers come in every shape, size and configuration imaginable. Likewise the inlets & outlets. If you can find an engine like your own that has one, it would be a good place to start. If not, generally, bigger is better. The only real possible downside is an arrangement that creates too much pressure drop across the system. Check with any of the actual IC manufacturers as they can provide specs for just about any engine.
NOTE: Most of what you see online are retailers...not builders.
