Old 03-06-2007, 10:15 PM   #1
Year: 1980
Chassis: 3 axle (10 wheel)
Engine: GMC 6-71 T
Rated Cap: 97
Send a message via MSN to Coalforge
Crown stop light switch
The stoplights on my Crown quit working today. After checking the bulbs abd the breaker, the next logical check would be the air actuated switch. Problem is, I can't find it. I am learning a lot about the bus but still no air switch. Does anyone have any ideas?
Wayne
Coalforge is offline   Reply With Quote
Old 03-06-2007, 10:43 PM   #2
frank-id's Avatar
Crown bus stop lite switch
The Crown buses use 2 switches to control the brake lites. One switch is in front under the dash. I think the switch you are looking for is mounted on the quick action valve located near/above the rear axle. To check the switch, it will require getting under bus. As ya may know if bus is running, and park brake is engaged, brake lites will be lited. The brake switch at rear can only be tested with bus wheels blocked, park brake not engaged, and wires on switch jumpered. The wires to the brake switch are both 14gage white wires. I'm gonna wire my front switch to another manual switch so when the bus is running, the rear lites will not annoy others. I could actually disconnect the front switch as my bus does not haul passengers. I installed a switch also to control the low air horn. Frank
Old 03-07-2007, 12:26 AM   #3
Year: 1980
Engine: GMC 6-71 T
Rated Cap: 97
Thanks
Thank you, Frank. I will take a look tomorrow. My Crown is the 40' with twin drive axles.
Wayne
Old 11-06-2018, 08:24 AM   #4
Coachwork: crown
Chassis: 2A-36-426
Engine: DD-6L-71T
any update on this? i was in/under my dash removing the antenna (to prep for paint) and now don't have tail lights (either when headlights are on or when brakes are applied)
what should i be looking for (going to assume it's the dash issue as opposed to the rear/under carriage issue)
mmime is offline   Reply With Quote
brake light switch please help littleangel47 Mechanical and Drivetrains 3 08-07-2019 11:24 PM
Ohio Crown 1971 Crown iusvir Skoolie Conversion Projects 19 04-02-2018 08:42 AM
need a STOP Light C00LR Classifieds | Buy, Sell, Swap 16 12-20-2014 07:59 PM
brake light switch please help littleangel47 Mechanical and Drivetrains 5 03-19-2012 01:19 PM
Help!! I can't stop stopping phillbus914 Conversion General Discussions 7 02-18-2006 01:36 AM
