Old 06-17-2011, 04:57 PM   #1
lornaschinske's Avatar
Rated Cap: 89
Cutlist: A FREE sheet goods cut layout
http://www.delphiforfun.com/Programs/CutList.htm
A "Cut List" shows how to cut a given set of parts from a given set of available stock. This program creates a diagram showing the stock pieces and how the required parts may be cut from them.
Data may created, deleted, modified and saved to a file for later use. Users can specify the width of material lost during cutting (saw blade kerf width), and the minimum dimension of waste material to report.
Solution searches give priority to crosscuts (vertical on the screen) or rip-cuts (horizontal) first or will try a Combination approach using all possible mixes of both types of cuts.
Since plywood and other sheet goods are getting more and more expensive, I do not want to waste any materials that I do not have to when it comes to building cabinets, etc. I also did not want to spend a lot (or any) money on a cutting program. This is FREEWARE. It's not a free trial or shareware, it is completely free.
Fulltime since 2006
Old 02-03-2012, 10:15 AM   #2
Re: Cutlist: A FREE sheet goods cut layout
Thanks
Sheet steel Zephod_beeblebrox2 Conversion General Discussions 19 12-31-2014 06:55 PM
Planning Layout for bus. Elliot Naess Conversion General Discussions 1 02-18-2013 07:47 AM
Plumbing layout lornaschinske Conversion General Discussions 1 07-10-2011 11:56 PM
Layout Opinions somewhereinusa Conversion General Discussions 6 02-15-2011 11:54 AM
floor layout diagrams adamanderr Conversion General Discussions 2 06-28-2008 11:36 PM
