Old 04-15-2006, 10:48 AM   #1
different size batteries in same bank
Let's say you have a battery bank with mismatched batteries. Example: one group27 and one group24, or one old and one new. If your charger is connected to the banks pos. line, how will it charge the batteries? My concern is it will charge the smaller battery fully and then proceed to charge the larger battery while cooking the fully charged smaller battery. Will a microprocessor controlled charger handle this. Or, if you have one battery going bad, will it affect the good ones?
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 04-15-2006, 11:45 AM   #2
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
The battery charger will overcharge the smaller battery and will not charge the bigger battery fully.
A bad battery, in a bank of good batteries, will draw down the other batteries. No matter how much you charge the bank, the bank will never get fully charged (you'll be lucky if the bank gets anything higher than the level of the bad battery). Please, just get rid of the bad battery.
Roasting8 is offline   Reply With Quote
Old 04-16-2006, 12:46 AM   #3
Steve's Avatar
If your batteries are hooked in parrallel they will not overcharge. The voltage will be the same across all the batteries and one cannot fully charge before another.
If one of the batteries is bad it will cause you to suffer battery lose when it is just sitting as the others in your bank will constantly trying to charge it. I think that having batteries in a large bank will help to keep any of the batteries from dying as long as you keep them charged.
** If you have a large bank of batteries, protect your investment and only use chargers that will automatically shutoff/trickle. **
BTW - I have three different sizes of batteries plus the engine battery hooked to my inverter/charger/transfer switch.
Old 04-16-2006, 06:36 PM   #4
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Sorry, I thought, for sure, that the smaller battery would start to boiling off before the big one.
Old 04-19-2006, 12:01 AM   #5
Les Lampman's Avatar
If the batteries are all connected together then the charger sees them as a "bank" and will respond to the voltage it sense from the bank and not an individual battery.
However...the charger doesn't know squat about each battery and any one of the batteries could be receiving much more current then is good for it (still charges to the correct voltage but does so in a way that damages it). Batteries have to charge from the surface of the plates in and thin plate batteries respond much differently then thick plate batteries.
For "best" performance (both charging and discharge) all the batteries in a bank should be of the same size and type. It's really even better if they're the same brand and age. That's what's "best" from a technical standpoint; lots of other things work and they're just fine if they do the job you want them to.
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Gauge size between batteries and converter? freedom_eagle Alternative Fuels | Electric, Propane, Wood Gasification, etc. 5 04-06-2012 09:33 AM
How Much Do You Have In The Bank? lornaschinske Conversion General Discussions 5 01-16-2012 05:15 PM
Battery Bank cjgbur Conversion Tutorials and How-to's 3 03-09-2011 04:12 PM
What size/type batteries jkindt Conversion General Discussions 2 02-20-2010 12:42 PM
Number of Batteries?/how to make a battery bank travlenhippie Electrical, Charging and Solar 0 10-22-2008 06:26 PM
