Old 12-10-2008, 09:58 AM   #1
Ray_WA's Avatar
Engine: 6.2 liter diesel
Rated Cap: 24
Re: Dirt cheap bus
What have they done to that poor bus?
-Ray
Pack up your bus and bug out to the hills!
Ray_WA is offline   Reply With Quote
Old 12-10-2008, 11:26 AM   #2
Ray_WA's Avatar
Rated Cap: 24
Re: Dirt cheap bus
That one I like!!
-Ray
Old 12-10-2008, 09:06 PM   #3
the_experience03's Avatar
Re: Dirt cheap bus
I honestly wouldn't mind undertaking a hot rod bus project. I just don't care for a lot of stuff on that one. The chopped look is cool, but they should have taken material out from below the windows for instance. Also, a FWD Eldo frame? If you're going to use an Eldo frame you might as well keep the 500 cubic inch monster that was supposed to be there, not that a 430ci blown Olds can't get up and move.
Old 12-10-2008, 10:24 PM   #4
Year: 92
Re: Dirt cheap bus
They're probably twisting the facts a bit and probably used a Toronado chassis, hence the Olds motor,
bbbrt76 is offline   Reply With Quote
Old 12-10-2008, 10:48 PM   #5
Re: Dirt cheap bus
It would be essentially the same chassis in either case. Heck, even if it was a Toronado chassis I'd still like to see a big inch Caddy between those frame rails or a 455 Olds. I have a hard time believing that building a blown 430 inch Olds was any cheaper than building any of the other choices. I think I need to start the search for a builder bus...
Old 12-11-2008, 01:18 AM   #6
Year: 92
Re: Dirt cheap bus
I think this one from one of the other posts would make a nice starting point
61 IH bus on Craigslist in WA
by TikiBus on Mon Dec 08, 2008 6:47 pm
http://spokane.craigslist.org/rvs/949112926.html
This bus is about a half hour from where Im docked, any interest?
I love Olds motors and the 403 is a mean one can't imagine with a blower on it but the whole front wheel drive thing just ruins, how are they gonna do wheelies with their bus?!!
Old 12-11-2008, 11:28 AM   #7
CAMO-MONSTER's Avatar
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
Re: Dirt cheap bus
IT WOULD OF COST ABOUT THE SAME TO WITH A HOLE HELL OF A LOT MORE POWER !
CAMO-MONSTER
hd d44 4.56, eaton ff 4.56
CAMO-MONSTER is offline   Reply With Quote
Old 12-11-2008, 09:57 PM   #8
Re: Dirt cheap bus
All that motor and a Fram filter of all things.
Old 12-12-2008, 10:37 PM   #9
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Re: Dirt cheap bus
that mack and that cornbinder are the cool ones
Old 12-12-2008, 10:38 PM   #10
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: Dirt cheap bus
The Olds "430" is probably no more and no less than the 425 that many Toronados were built with. It's better for a blower than a 455 due to the forged steel crank (455's had cast cranks).
Jarlaxle
Old 12-12-2008, 11:38 PM   #11
Year: 92
Re: Dirt cheap bus
The original ad in the link says 403 olds but it got transposed into 430 somewhere in this thread
Old 12-14-2008, 08:11 PM   #12
Engine: DT466/MT643
Re: Dirt cheap bus
Ye gods...a 403 with a blower is a hand grenade. 403 blocks are Oldsmobile's weakest, with gray iron crankshafts, hollow main bearing webs, and thin cylinder walls.
Jarlaxle
Old 12-14-2008, 10:30 PM   #13
Year: 1974
Chassis: GMC-6000
Engine: 454 CHEVY
Re: Dirt cheap bus
ALONG WITH THE 78 AND UP 350 ARE WINDOW MAINS.
IF YOU WANT A GOOD SMALL BLOCK OLDSMOBILE TRY
THE PRE 77 OR THE 350 DEISEL 4.057 STOCK BORE YOU
CAN STROKE IT TO 411",OR 437 SAFELY OR WITH
SONIC AND MAGNAFLUX TESTING YOU CAN GO AS FAR
AS 451".
IF YOU THINK I'M BLOWING SMOKE GO TO
JO MODELOW MOTOR SPORTS YOU CAN LINK TO IT THREW
http://www.442.com/
YOU WANT THE ARTICLE ON THE 440 STROKER SMALL BLOCK
http://www.mondellotwister.com/ArtStroker440.htm
YOU GOT TO CHECK OUT THIS Jim Kubicka's 1954 Olds Super 88 Restoration
Old 12-15-2008, 07:27 PM   #14
Engine: DT466/MT643
Re: Dirt cheap bus
PLEASE STOP YELLING!
Jarlaxle
BB Bus for cheap frank-id Classifieds | Buy, Sell, Swap 0 08-09-2014 11:17 AM
Cheap 16' Awning timbuk Classifieds | Buy, Sell, Swap 1 12-06-2008 05:49 AM
Where to get cheap batteries? phillbus914 Electrical, Charging and Solar 3 11-29-2008 10:22 PM
55 gmc on ebay - Cheap! captainkf Everything Else | General Skoolie Discussions 0 01-15-2007 06:31 PM
What's the dirt on "cheap" diesel gensets v. onan? runnysucklehose Conversion General Discussions 2 06-21-2006 06:16 PM
