Old 03-25-2018, 10:05 PM   #1
Do I frame or floor first?
Do I frame or floor first, I already have subfloor in but not sure how to start the next step also not sure the flooring, if I put in laminate I won’t be able to bolt through it because of the floating floor rules right?with the the expanding and contracting it would buckle if I bolted through it right?
Kind of confused thanks guys
Lherrlinger is offline   Reply With Quote
Old 03-25-2018, 10:46 PM   #2
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
I'm curious about this as well, as it will be up very soon for my build.
https://www.skoolie.net/forums/f11/n...tml#post256987
My build thread - Started 3.2.18
jjhwick119 is offline   Reply With Quote
Old 03-26-2018, 12:51 AM   #3
Rated Cap: 37,400 lbs GVWR
My finish flooring will be the last thing I install. I don't want any of it under walls, cabinets or anything else, whether it's floating or not. It will take more time to laboriously trim the flooring around walls and cabinets, but if I ever need to replace it in the future it will be much easier than tearing apart the whole interior. Besides, what good is flooring under cabinets/fridges/etc if you can't even see it there?
Old 03-26-2018, 09:19 AM   #4
lwharma's Avatar
Chassis: Type D chassis manufactured by navistar
Engine: T444e 7.3l V8
Some good points above. From a design standpoint, if you install your floor after, just make sure any flip up cabinets along the floor also have flooring or some sort of finishing so you’re not looking at (or snagging your stuff on)plywood every time you access these cabinets. If you use a sheet vinyl, it will be easier to pull through and install in an empty bus and you won’t have to worry so much about perfect edges. They come in a lot of different styles now and look nice. You won’t have to worry so much about liquid spills with sheet vinyl.
lwharma is offline   Reply With Quote
Old 03-26-2018, 09:23 AM   #5
lwharma's Avatar
Here is an example of nice sheet vinyl. No cracks or creases so no worries about liquids, dirt, etc. good protection for subfloors. Just make sure you have a nice smooth surface like a thin layer of smooth lauan.
Old 03-26-2018, 11:22 AM   #6
Mgulley82's Avatar
Chassis: 40' Saf-T-Liner MVP ER
Engine: CAT 3126 7.2L
We are laying down 1” XPS foam board, a layer of plywood/obs, then one solid sheet of vinyl before framing and installing the interior
Our flooring cost $200 total for 38’ of vinyl at the local wholesale flooring warehouse
Mgulley82 is offline   Reply With Quote
Old 03-26-2018, 11:58 PM   #7
Thanks guys
Is the vinyl thick enough to kill vibration? Also would I be able to screw through laminate withought it buckling?
Old 03-27-2018, 05:22 AM   #8
Mgulley82's Avatar
XPS foam Board should take care of much of the vibrations
Vinyl sheet is just a thin veneer layer over all your sub flooring
Old 03-27-2018, 09:00 AM   #9
lwharma's Avatar
I don't think you'll have any pulling or twisting with such a large sheet of vinyl. I feel like it will hold it's own. If your screwing a 2x2 down on the floor for framing, have someone hold the wood firmly in place while you screw it down. That should give some extra protection so the screw won't pull and twist the vinyl. I feel like the vinyl will be fine since it is such a large sheet. Start a little more cautious and feel your way through it.
Old 03-27-2018, 09:34 AM   #10
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Right on!!
JD - Full timer out west
My Adventures & Build
Old 03-27-2018, 03:31 PM   #11
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
I framed on top of the subfloor and then floored each area seperate.
Used a heavy duty vinyl under the kitchen cabinet,sink,stove,fridge area and turned the edges of the vinyl up the framing to create something like a wet area and did the same in the bath,toilet,water heater area.
Mostly Only did floating floor where it could be seen but I did use the scraps and extra to fill in under my sofa,beds,seats that are all storage.
A floating floor has to float.
I know?
Did my entire house and cut the boards tight to the walls and it lets us know what the weather is doing as far as dry or humid.
Good luck
Old 03-27-2018, 08:02 PM   #12
Flooring
I think I’ve decided on rubber diamond pattern flooring kind of like what they use in garages, 40’ long and4’ wide only like 250 bucks I’ll lay this down then start my framing, if I dont like it I can just throw something else on top because it’s only2.5 mm thick. Any advice on doing side walls?
conversion, floor, flooring, help me, short bus
