Old 05-01-2016, 12:07 PM   #11
Robin97396's Avatar
I don't know about the rest of you, but many of my rivet holes are all stretched out. I had to use some small lag bolts to temporarily hold up the panels.
Old 05-01-2016, 02:16 PM   #12
Chassis: International S3800
the common theme seems to be that I should down the ceiling and replace the insulation but that my ceiling isnt likely to go back in...
I REALLY am dead set against a wooden ceiling.. I just dont like the look... I like my bus to feel like a bus...
what are alternatives of something i can put up that still lets me feel like I have a bus?
Old 05-01-2016, 03:05 PM   #13
There are a lot of Formica type products in many finishes (including metals) that could be applied using minimal wood to attach it to.
There are also quite a few vinyl plank and wall covering items that come in a wide array of choices. I will be using vinyl planks on my walls in a light, birds-eye maple look to keep things bright (but then, I like the wood look). Also easy to install and clean.
And there are some really durable commercial & architectural wall coverings out there too that mimic everything from metal to bamboo to stone to you name it. Almost too many choices.
Old 05-01-2016, 03:13 PM   #14
Jolly Roger's Avatar
Engine: Detroit 8.2
I stripped the floor and followed the leaks until I found where. They were and followed the trail and that is the only steel or insulation that was replaced and it was replaced with duct board fibreglass insulation that was available to me at the time and cleaned and sealed every roof/body seam thereafter with no farther issues and I don't plan on camping in anything colder than the winters of NC or TEXAS or anything between?
It ain't the bus it's me.
Old 05-01-2016, 03:15 PM   #15
Robin97396's Avatar
Depending on how nice of a job you do of removing your ceiling panels you may be able to replace them after you've insulated. I think it's to much trouble and they are always going to have the chisel marks on the surface edges of the panels. I do like the durability of bus interiors and was trying to think of a way to insulate without taking the panels down by injecting spray foam. It has been tried. The old insulation gets in the way. I slowly came to the conclusion that to retain heat/cold I will need insulation. I don't know what I'm using for an interior after I've insulated.
One thing I'm wanting to try is making a 2' x 20' awning for each side of the bus that will only cover the windows when folded against the side of the bus. Similar to tinning over the windows, but like an awning that could be raised to either completely cover or expose the windows for full window access and visibility. Each awning cover could contain insulation, and it may be possible to mount smaller solar panels on them.
I never said I always have good ideas.
Old 05-01-2016, 03:20 PM   #16
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
...what are alternatives of something i can put up that still lets me feel like I have a bus?
You might consider the whiteboard-like material available at Lowe's for cheap: it's smooth and white and will bend, and 4'x8'. It's used a lot for walls in gas station restrooms. Hm. Well, it might be useful...
To keep cool (with or without roof insulation), consider too a shade setup over the top of your rig. Does wonders, from what I've read.
Dapplecreek is online now   Reply With Quote
Old 05-01-2016, 04:32 PM   #17
Robin97396's Avatar
Bing Mr Creek. Vehicles outfitted for hot environments have a second roof with an air gap in between. I've been looking at that for years, and it's not that much further expense wise to make a deck up there.
Ok, no art jokes.
A deck on top of the bus that also acts as a sun shade for the roof of the bus. Deck rails that also fold down and cover the windows, or they can be positioned like a small awning to keep sun from blaring through the bus.
This is the only thing that I've thought of but haven't seen anybody try already on this site.
Old 05-01-2016, 06:53 PM   #18
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 8 Assengers 2 ATV's
....it had crossed my mind using an old stake and rack style trailer for parts. Fab some mounting brackets for each side of the bus, aluminum cross bars, and a white tarp....all removable for road trips. Air flow between the tarp and roof.
...also not removing steel ceiling, toy hauler/camper use.
Old 05-01-2016, 07:22 PM   #19
Originally Posted by REDD View Post
Attachment 10058
cool idea for insulating the roof.. almost like an umbrella effect.. only issue would be if the wind caught it.. or maybe its a material that blocks alot of sunlight but can still breathe so less likely to be caught by the wind..
I kind of like the idea of the wall protection material.. we see it often in Service hallways of Hotels.. easy to clean and still has that modern feel...
I could place the panels into some HVAC Z-channel.. which could give them room to flex as the bus does.. I do know when it gets really cold that the wall protection material becomes brittle.. if it were not screwed down itself (but the Z-channel is) then it has a chance of not breaking...
ive watched them try to work with it in the cold breaking it when trying to cut it for install...
its an idea..
of course lots of speculation for a bus that I dont have in front of my house yet.. im having the body work done on it professionally since I dont have the facilities or knowledge of how to fix rust and paint a bus in a multi-color scheme...
I do know when I was inside it down in warm humid rainy florida to drive it and go over it, that it didnt smell musty inside like some of the busses i had looked at in the ast couple months.. so perhaps im one of the lucky ones that doesnt have a lot of mildew to contend with..
we will know soon though because the only spring / summer allergy I ever get is to Molds.. so If I drive it with the windows closed and start to stuff up and sniffle I'll know there are molds / mildews I need to rectify..
I may pull down a single panel and see what the insulation looks like.. I should be able to pull one down without destroying it to see what im dealing with...
for climate control im not too worried.. im installing a 50,000 BTU A/C in a 7 row bus, and it has 5 Heaters in it already, plus the A/C unit I got has a heater core in it which I will hook up... that allows me to use the A/C in cold or rainy weather to dehumidify and then re-heat... similar to what is done in most cars these days... and for what i did a LOT of work to my last bus to make happen.. pre-cooled defrosters...
I never thought once about removing the ceiling in that old bluebird.. and I never had a problem with it.. sometimes I wonder if too much knowledge creates undue stree over a portion of a project...
Old 05-01-2016, 09:11 PM   #20
The old Range Rover safari models came equipped with a standoff roof. Simple idea that works. Attach a sheet of metal (aluminum, in their case) a few inches above the factory roof to allow airflow and viola..the rig is always in the shade. Makes a HUGE difference. I will be building a roof deck to accomplish the same thing.
