Old 12-14-2006, 01:03 AM   #11
Elliot Naess's Avatar
Engine: 5,9 Cummins
Very good. Obviously, I'm spoiled by the late model electronically controlled engines at work -- turn the key and the komputor handles everything. Millicent will get a loving kick in the pump next time I go to start her. Maybe we used to do that at work in the old days -- that was a couple million miles, and a lot of brain cells, ago!
Elliot
Old 12-14-2006, 07:27 PM   #12
Coachwork: Ward Genesis
Engine: DT466/MT643
No B-series Cummins has glow plugs. Some (most) do use a heat grid in the intake...it will still start without it, but it certainly won't pretend to like it.
Jarlaxle
Old 12-14-2006, 09:17 PM   #13
phillbus914's Avatar
Originally Posted by Elliot Naess
I think it helps to goose the foot feed to make it fire. As soon as it fires, it runs beautifully. Do you guys step on the accelerator to fire it?
Mine does the same thing. When I first got it it would start without doing this. Ever since Jason turned up my governor I have to tap the gas pedal to make it start.
I'd like to know why this is also. Please post if you find a fix.
My Old Bus :(
Old 12-14-2006, 10:01 PM   #14
Engine: 5,9 Cummins
Very good. Apparently, I don't have the heat grid. No problem.
I don't consider that it needs fixing. I'm just trying to learn the best way to start it. But if I learn something, I'll post it, you bet.
Elliot
Glow Plugs & Electrical issues Mechanical and Drivetrains 0 08-12-2013 11:00 AM
220 NHH Glow Plug in intake? opus Cummins Drivetrain 9 08-03-2012 08:06 AM
Cummins 235? nevrenufhp Cummins Drivetrain 2 07-28-2012 08:52 AM
Why are there no glow plugs? Diesel Dan International | Navistar Drivetrain 4 02-16-2011 12:40 PM
ARG!!! Glow PLUGS - help ParadigmCrime Everything Else | General Skoolie Discussions 2 01-23-2007 06:56 PM
