Old 11-11-2007, 03:12 PM   #1
odyssess's Avatar
Engine: T444E 3800
Doesn't anyone know how to replace the plastic window clips?
Doesn't anybody out there have any idea how to replace broken window slides? These are the two little push slides we ALL have to slide the windows up and down. Anyone? Anyone? Bueller? I just snapped another one opening a window. They seem to break in half easy. I can't seem to find any info online about it. I can't believe I would be the only one. Well, maybe I can believe it. It would be my luck.
http://www.skoolie.net/gallery/v/Skooli ... Green+Bus/
Keep on Keeping on.
odyssess is offline   Reply With Quote
Old 11-11-2007, 06:49 PM   #2
KC10Chief's Avatar
Rated Cap: 60
Re: Doesn't anyone know how to replace the plastic window clips?
I looked into it and it doesn't look fun. What I did, was move those windows to areas where I know they will never be opened. I then used some TEK screws to fix them up for good. I moved my good windows to spots where I will be using them.
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
http://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 11-11-2007, 11:17 PM   #3
odyssess's Avatar
Engine: T444E 3800
That's the best you got???? Just replace the windows??? If my battery died should I replace the engine???? Seriously, there aren't any scrap busses around here I could even get spare windows from. It looks like the top part of the window can maybe be tapped upwards and I can get at it that way. Anyone with any experience tried this?
Keep on Keeping on.
Old 11-12-2007, 12:21 AM   #4
swinada's Avatar
I know that will not help much, but I do have about 24 windows sitting around I dont need anymore.
That's the best you got???? Just replace the windows??? Anyone with any experience tried this?
For some things you might be the first....but make sure you pass on the knowledge gained douring the repair process because I'm sure you will not be the last to run into this problem.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
http://picasaweb.google.com/swinada/BusPictures http://www.swinada.com/bus.htm
http://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 11-12-2007, 12:31 AM   #5
the_experience03's Avatar
Originally Posted by odyssess
Bueller?
No really...
My window slides don't work for $hit. Where abouts are they snapping? Is it an internal thing or can you atleast see where they are cracking? Someone might have some spare windows laying around from an RV window install on the board and that might be your best bet. Otherwise you are taking my route I think and JB Welding them.
Old 11-12-2007, 10:54 AM   #6
odyssess's Avatar
Engine: T444E 3800
They are snapping right in the middle where I can see them, taunting me!!! I found a website that sells the replacement slides for a $1.63/ea. but they do not have any instructions. The plastic welding might be my best option so far. Anyone near Vegas with some extra windows??
Keep on Keeping on.
Old 11-12-2007, 11:31 AM   #7
KC10Chief's Avatar
Rated Cap: 60
I'd say, order a couple of those slides. When they come in, you can see better how they work. If it's not feasible, then you have only spent a little over $3. You can take the window out, and take it totally apart. You might be able to order that top piece that goes across the top of the top window and has the latches in it. Can you order it already assembled?
Matt
7.3L diesel w/AT545
Old 11-12-2007, 02:05 PM   #8
odyssess's Avatar
Engine: T444E 3800
I have only found the plastic pieces and springs, I havent found any pre-assembled tops. I'm going to try tapping the top off when the new slide pieces come and replace them from under the top portion. My only worry is the seals around the window. I don't want rattleing windows. I'll let everyone know what happens.
Keep on Keeping on.
Old 11-13-2007, 11:55 AM   #9
nyrockingchairs's Avatar
What about finding your local bus yard and asking them? I notice those sort of places don't get mentioned here for some reason. Though if I had a problem one of the first places I go is one of my local bus yards to see what they have to recommend. Maybe because we are in the country and the local bus yard is my neighbor though...they also keep an awesome bus junk-yard so I buy stuff from them as well.
1988 Chevrolet S6000 8.2L Detroit Diesel
nyrockingchairs is offline   Reply With Quote
Anyone have A/V clips of a mid 80's FE with the 427/5 speed? BlueBirdgas Everything Else | General Skoolie Discussions 2 05-10-2009 03:57 PM
NY's 'R' Endorsement doesn't cover air brakes Hex Titles, Insurance, Registration and Money Matters 9 11-24-2008 09:41 PM
Looking for 80's FE video clips BlueBirdgas Everything Else | General Skoolie Discussions 0 04-22-2008 10:11 PM
How do I replace the plastic window slide clips? odyssess Conversion General Discussions 1 02-12-2008 11:23 PM
Screen doesn't fit my monitor Foggy Dewhurst Forum Admin | Account Help | Suggestion Box 3 12-21-2006 07:41 PM
