Old 05-30-2019, 08:27 AM   #1
Coachwork: Chevy
Chassis: C60
Engine: 8.2 diesel "Fuel Pincher"
Rated Cap: GVWR 27000
Driving my Detroit 8.2 across AZ mid June...
I'm making my first family trip from KS to AZ. I don't think it'll be too hot but I'm doing an oil change before I leave.
Should I just stay with the rotella 15/40 or use something straight?
Stick with rotella?
I'm going to flush the system too, and keep my eye on the temp.
No need to blast me about the engine, I know, I know... It's got 76k miles and runs good. So I'm sticking with it and babying it until my next build (don't tell my wife I said that).
meyermobile is offline   Reply With Quote
Old 06-01-2019, 08:27 PM   #2
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
Rotella 15/40 is fine. Itís up to you whether you go with a synthetic or conventional. I went with conventional because of cost and the amount of miles I do (or lack thereof) justifies it.
WARGEAR is offline   Reply With Quote
Old 06-02-2019, 06:54 AM   #3
Coachwork: Chevy
Chassis: C60
Thanks Wargear!
Old 06-02-2019, 12:39 PM   #4
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
i have the same motor in mine and at 200,000 miles it still runs like a top.
good maintenance before you go and you should be fine.
i would worry more about the transmission temps on a long road trip?
hope you have a good trip and have access to old school mechanics that know the 8.2 if you have any issues.
they are few and far between around here and you gotta have special tools to mess with the fuel rails.
wish you luck and successful journys
Old 06-03-2019, 07:34 AM   #5
Coachwork: Chevy
Chassis: C60
Thanks Jolly.
Is there an easy way to keeping track of the temp of the transmission. Maybe a wireless thermocouple?
Would like to keep an eye on that.
Old 06-04-2019, 03:45 PM   #6
Year: 86
Chassis: Ford B700
Engine: 8.2
only way i know to get a true fluid temp reading is to cut a tee in the lines and add temp guages to the dash.
i dont think a thrmo couple would read the actuall temp. exactly because it would also be reading the temps of the metal it is attached to.
what transmission do you have? some have tappings in the transmission for temp guages.
maybe other members hear will chime in and offer more experienced thoughts?
without having computers on our busses we have to go more old skool than just add it into the computer.
