Old 07-14-2006, 11:33 PM   #1
lapeer20m's Avatar
electronic ignition
quick question for you electronic wizards out there.....
i want to find/buy/make a circuit that switches off and on several times per second. What i want to do is connect this switching circuit to an automotive ignition coil to make a spark plug spark.
anyonw have any simple ideas?
Old 07-15-2006, 12:43 AM   #2
eggman's Avatar
I am no electronic genius by any means, but would an automotive flasher work?
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 07-15-2006, 01:35 AM   #3
frank-id's Avatar
Spark trigger?
What is the purpose for the spark device.? Flaming exhaust? Use an old distributor and turn with 12 volt fan motor with a speed control. Frank
Old 07-15-2006, 04:39 AM   #4
lapeer20m's Avatar
it is for a flame....propane powered. Size and weight and energy consumption are all issues since it's for a bicycle.
A flasher is an excellent idea, but just isn't fast enough........oh wait....perhaps a flasher that does not have the proper load will flash fast enough......(ya know how it flashes fast when you have a burned out bulb, that just might be the ticket)
I'm gonna go play with that idea!
Thanks
Jason
The distributor powered by a fan motor is good too, but not for the bicycle application (although i dind't mention bicycle in my original post)
We're working on "art" projects for burningman
Old 07-15-2006, 01:33 PM   #5
frank-id's Avatar
Burning man
I'd sure like to go to that event. Costs lots of money.
My suggestion for a vw or similar distributor could work great. The distributor could be driven from chain or tire. The unit would add some artsy
flavor. I wanna build a motorized picnic table. Got any pics to share?
Frank
Old 07-15-2006, 08:29 PM   #6
the_experience03's Avatar
The commercially available kits just use a $5 parts store coil and a spark plug. They just turn the thing on and off with a relay. I'm sure something like that could work.
Old 07-16-2006, 12:08 AM   #7
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
What about those little generators that contact the tire & spin to make a bicycle headlight work? Couldn't you convert the frequency to something usable for your application? That way, as long as the bike is moving, it would have a signal. Of course, signal speed would vary with ground speed without some sort of frequency clip, i.e. headlight brightness is directly proportional to bike speed.
L'il help there, Electrotechies!
Griff is offline   Reply With Quote
Old 07-16-2006, 02:46 AM   #8
Correct me if I'm wrong, Jason, but I don't think you want this thing to be working while you're driving so the tire operated gizmos wouldn't work, correct? I still say go with the generic $5 tractor coil.....
Old 07-16-2006, 09:28 AM   #9
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
There is a web site you can buy exhaust flame kits.WWW.eatmyflames.com I think it's only $45 for a single.
What happens on the trail stays on the trail
Kirbystud is offline   Reply With Quote
Old 07-16-2006, 07:31 PM   #10
lapeer20m's Avatar
the coil and a spark plug are not a problem....the problem is how to make it spark.
dewalt 14.4 volt batteries will be used to power the contraption.
When it comes to wireing a 12 volt coil...
Obviously for the high voltage circuit you connect the center of the spark plug with an insulated wire, ground the proper part of the spark plug
the low voltage circuit you connect your ground all the time to the proper terminal, then you connect the hot wire to the proper terminal, and when the hot (+) wire is REMOVED from the terminal the spark plug sparks.
What i'm trying to find, is an electronic device that will connect then disconnect the hot wire going to the coil several times per second.
I think the turn signal flasher will work...the old mechanical type that flashes real fast when you have a burned out bulb in the circuit. I would estimate it to flash at 2 or 3 times per second.
If you had a small propane powerd flame thrower on your bicycle, wouldn't you use it while riding???
I am actually rather amused by the idea of spinning a distributer with the rear tire.......but getting all the geometry correct would be a little difficult..i'm not sure i have the desire to make it bullet proof enough to work everytime. IT is very important to make sure the propane ignites on it's way out of the flame thrower. Unburnt propane floating down toward the operater is less than desirable. Propane is heavier than air. Although it is being used in outside in a well ventilated area, which will certianly help to reduce the danger. I do not remember the LEL and UEL of propane off the top of my head. Natural gas would be a much safer fuel for this setup, but it's difficult to find lng in a bottle. It is used by some city buses and cabs, but not nearly as easy to find as propane.
The propane cylinder (coleman grill size) will be mounted in a safe spot that is easiy accessable to the rider and can be turned off with a quarter turn valve if necessary. The nozzle for the flame will be about 8 feet off of the ground and pointed straight up. The size of the flame should only be about 6 or 8 feet above the nozzle. (as opposed to 30-50 feet for my full size flame thrower)
A super easy and portable electronic ignition would be a tazer, but regular citizens cannot purchase them here in michigan. I think they run off a 9 volt battery or something similar.
Ignition cut-off problems CostelloCrew Conversion General Discussions 4 11-06-2014 07:00 AM
Electronic Pickpocket timbuk Everything Else | General Skoolie Discussions 0 12-05-2010 10:17 AM
Electronic devices and winter temperatures. arfisher83 Everything Else | General Skoolie Discussions 3 10-01-2008 08:46 PM
Blue Bird Ignition Interlock paul iossi Conversion General Discussions 0 08-20-2007 11:51 PM
Electronic LED moving display Steve Conversion General Discussions 1 12-16-2003 09:40 AM
