Old 11-12-2016, 02:16 PM   #1
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Emergency door dimensions? (Esp. RE)
How tall and wide an object could you fit through your emergency exit door? And which manufacturer, type, and year is it?
I want to move an upright piano and would prefer not to have to take a chainsaw to it or the bus.
I'm particularly interested in the side door of a pusher bus. The back door of the 2002-or-so International conventional bus I measured was 57", if I recall, which is plenty.
Thanks!
Dapplecreek is offline   Reply With Quote
Old 11-12-2016, 02:42 PM   #2
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
Side doors aren't typically gonna be more than about 24 inches wide. You may find one that's 26 or 28 but I wouldn't count on it. My bus is 250-ish miles away right now so I can't go check it but when I get back home I will.
Old 11-12-2016, 02:54 PM   #3
Thanks - width isn't the biggest worry - it's height. But it would be wise for me to know both before a purchase. I was just hoping to know if those doors were anywhere near large enough.
Old 11-12-2016, 03:12 PM   #4
AlleyCat67's Avatar
Year: 2005
Height.... again I'm not 100% certain but I'm thinking in the 48-54 inch range, give or take.
Here's a view of mine, maybe this will help.
Old 11-12-2016, 03:16 PM   #5
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Your upright probably won't clear. Side doors are usually not much higher than floor to driprail sub-5' range
Captain Obvious on deviantArt
