Old 05-29-2017, 12:00 PM   #1
wendysdrivethrudude's Avatar
Flooring from 2x4 ends
I saw this and figured that the skoolies on here would like to see it. You get the look of tiles or pavers without all the cracking, the ends could be cut as thick or thin as needed with just a miter saw, and 2x4s are rather inexpensive. Just seal them and lay them with something flexible and you're good to go.
The Endeavor Build Thread
wendysdrivethrudude is offline   Reply With Quote
Old 05-29-2017, 06:31 PM   #2
Looks great!
I understand that they need to be small to not crack, but I can only imagine how much time that would take.
It would save a lot of weight if you were planning on a stone or ceramic tile,
John.Smith is offline   Reply With Quote
Old 05-29-2017, 08:04 PM   #3
That really does look good! And Roger the flexible adhesive.
Old 05-29-2017, 09:08 PM   #4
Chassis: Still dreaming about a bus
Bob Villa used this on a project, he called it 'cobbled wood". He used weathered lumber that had check cracks and other imperfections to give it some character. For grout he mixed sawdust and varnish and applied it with a grout float. The tiles were glued using a vinyl adhesive so water in the glue wouldn't affect the wood. The finished project looked great.
Lamacose is offline   Reply With Quote
