Old 07-21-2018, 01:08 AM   #1
Flooring Idea?
Would this be suitable for a floor? It was recommended to me by a friend. What are your thoughts?
https://www.homedepot.com/p/Amdry-2-...FVc-TwodIrwEdQ
Jsayah is offline   Reply With Quote
Old 07-21-2018, 10:03 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I don't think anything made of OSB is suitable for any construction anywhere. If it gets damp it's toast, won't hold a screw.
Old 07-21-2018, 05:28 PM   #3
Thanks for the input I decided to go back to my original idea of pink rigid foam and liquid nails to make a floating floor. Was also thinking of using some of the good stuff spray foam to fill the gaps on the edges.
Old 07-21-2018, 05:34 PM   #4
Where are you using the Liquid nails?
Old 07-21-2018, 09:48 PM   #5
Just gonna get the stuff built for use with rigid foam insulation and do it between the floor and the insulation then the insulation and the plywood.
