Old 04-17-2016, 12:02 PM   #21
Chassis: International S3800
Originally Posted by Robin97396 View Post
150k is pretty average for retirement of buses. Generally we look for something under 200k.
interesting.. I never realized they ran that many miles on them.. I wouldve figured 100k or so..
I should feel lucky that mine has 85k on the body and from what "appears" to be 40 or less on the motor / tranny.. (it was overheated from the pieces i can put together)..
Old 04-17-2016, 01:00 PM   #22
Robin97396's Avatar
Yeah, typical motor pool SOP. Signs of trouble and they will put a vehicle on the chopping block.
Oh, that's too bad. You've only got 15k left before you hit the magic number of 100k. With proper care you should be able to exceed 300k. These are industrial vehicles.
Old 04-17-2016, 06:13 PM   #23
Lol and only like 40k on the drivetrain.. the motor and trans were replaced at the same time... I pretty much have a new bus.. which is good since I plan to put Miles on it.. Lots of them..
Old 04-17-2016, 06:22 PM   #24
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
My baby JUST clocked 151K miles with 22K miles on the rebuild. The engine runs super sweet, she shifts like new, and she has a sure-footed driving feel. NO slop in the steering at all!
Hope this helps.
M1031
M1031A1 is offline   Reply With Quote
Old 04-17-2016, 07:54 PM   #25
Robin97396's Avatar
Mine seems to wander a bit, but have you noticed how skinny the back county roads are. It's exciting to pass a logging truck that also takes up a full half of the road.
I've got like 164k on mine. I've only put a couple hundred miles on it since I've had it. Working on stripping the interior now that heat isn't an issue.
On a side note if there are any Korean grocery stores in your city you can get usually a electric heating pad about the size of your mattress. Actually they seem to come in twin and full size approximately. Just got one, about $60, but that might have been on sale. I think they're usually about $100. Blanket sales aren't so good this time of year. No link.
Old 04-18-2016, 03:02 AM   #26
I would be highly suspicious of any odometer on a school bus that old that says it only has 31K miles.
On average, over the life of a bus, most buses put on 10K per year. In the early years perhaps as many as 20K but in the later years, particularly if they spend time on the spare line, less than 5K per year. 15 years=150K miles.
As it has been noted above, increasing the HP will not increase the top speed. Increasing HP will allow you to keep going the top speed without slowing down on any hill.
In order to go faster you will need to change the final gearing. The easy and cheap way to get about 5 MPH more top speed is to replace the current tires with taller tires. Another way would be to change the rear end gearing to a lower numerical number in order to get the top speed up. But in order to go faster you will most probably need more HP to do it. More HP can cause overheating problems, particularly on hills in hot weather.
Which is why I advocate very strongly to find a bus with the power package and gearing you want at the start. It may cost more than the one that is close by but you will save many $$$$$ over for what it will cost to update and upgrade a bus that won't travel at highway speed.
Old 04-19-2016, 03:43 AM   #27
tincaneasybakeoven's Avatar
Year: 95
Coachwork: Amtran ss-33
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
spot on! gearing first; and then hp; to help reach new top end speed diesels are torquers and dont like to rev unless yor a 5.9 with 4k springs and heavier duty valve train/ titanium components. then you like to rev. most have a sweet spot right around the torque peak
claim common law i, a man; claim.... on facebook
if your not a man our doing it all wrong-kp
tincaneasybakeoven is offline   Reply With Quote
Old 04-19-2016, 03:46 AM   #28
Year: 95
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
im looking at a 3.55 for highway speeds. its 4.44/60 now.
Old 04-19-2016, 06:25 AM   #29
Coachwork: IC
Chassis: CE300
Rated Cap: 32
4.44/60 is pretty good.
How fast you looking to take the easy bake oven?
Roll Your Own Build Thread
Old 04-22-2016, 10:54 PM   #30
Well I thought I had a bus, but some dude from florida sent a mechanic to look at them and i guess he put a high max bid on them. every time i bid im instantly out bid..... starting to give up on this dream. Been trying to buy a bus for almost a year now
jbohall001 is offline   Reply With Quote
