Old 05-15-2015, 07:57 AM   #1
austin1989us's Avatar
Chassis: TC/2000
Engine: Cummins 5.9TA
Fuel Economy
So, in case you didn't read my intro thread, I'm shopping for a bus. I think I found a good Oklahoma bus and am thinking of taking a look at it next week when I'm up there. The problem is that it runs on gasoline.
I'm trying to do a quick break-even analysis and wanted to run some numbers by yall to see if I'm on track.
I'm assuming that a 6 window diesel bus (GVWR under 26k) will probably get around 12 mpg. The same bus with a gas engine I'm assuming will get 8 mpg. I'm also assuming a gas cost of $2.50/gal and a diesel cost of $3/gal. I think I'll probably put around 2,500 miles on the bus per year.
That equates to the gas bus costing ~$150 more per year in fuel. I assume that after parts and maintenance the gas bus will cost about as much as the diesel (maybe less).
Am I out of line with my assumptions? Any input would be appreciated.
Thanks,
-Austin
PS: I'm a newbie, so I don't think it'll be easy to post a link. But take a look at the 1989 Chevy bus for $2,500 on the Oklahoma City Craigslist page. It looks like it's built on a medium duty truck chassis. I'm not talking about a van-bus here.
austin1989us is offline   Reply With Quote
Old 05-15-2015, 08:09 AM   #2
Don't have any specific stats to offer but can assure you that given reasonable maintenance, the diesel will prove to be much more cost effective than that. Most of the v-8 gas buses I have seen were doing well to get 4-6 mpg and required much, much more in maintenance costs over time. A properly tuned diesel (most likely a 6 cylinder in that sized bus) can get around 14 unless lead footed. I have "heard of" a number of similar rigs put together by mpg fanatics that can get about 20 with the right gearing and tires.
Bottom Line: If the economic benefits weren't real and compelling, most commercial OTR operators would be driving gasoline rigs instead of diesel.
My two cents.
Old 05-15-2015, 08:56 AM   #3
My 1985 Thomas/Ford got about 3 or 4 mpg. On the highway even.
Old 05-15-2015, 09:43 AM   #4
I have had a lot of experience going thousands of miles in buses over the last forty years.
I know that fuel mileage numbers vary with experience but I think you are way over optimistic on fuel mileage expectations. The spread between gas and diesel in a medium duty will be about the same but you need to revise both down about 2 MPG.
I have seen some Blue Bird TC2000 buses with the 5.9L and AT540 that got 10-11 MPG. But those were relatively light buses running on relatively flat routes going less than 35 MPH. On trips they would actually use more fuel per mile--frontal area and speed eat up a lot of fuel.
The best fuel mileage we ever experienced with a gas powered bus was a 1979 IHC S-Series with the MV404 and 5-speed direct with a 12-row Carpenter body. On trips it consistently got 7.5 MPG. It was geared to a top speed of 67 MPH and would cruise easily at 55-60 MPH. The same bus with an automatic got 5.5 MPG doing the same stuff. The same basic bus with an MV446 got 4 MPG doing the same stuff.
Most DT466 equipped buses with a top speed of 57 MPH got 7-8 MPG.
Most 5.9L equipped buses with a top speed of 70 MPH got 8-9 MPG.
Most Cat 3208(T) equipped buses with a top speed of 70 MPH got 7-8 MPG.
Most 6.9/7.3/T444(E) equipped buses with a top speed of 65 MPH got 7-8 MPG.
As with everything else, your results might be different.
Old 05-15-2015, 10:03 AM   #5
Right on, all drivers are different regarding fuel mileage.
On a trip I drove my brother's PU after he got tired and got 1/3 better MPG, slower speed though.
Our 5.9 powered TC1000 is at 11.5 right now avg. I am a very conservative driver and cruise at 55. Most miles have been towing 4500 lbs. with very little long hwy. runs. Our TC weighs just under 20K.
I have a Scan gauge D and watching the current mpg really helps make you aware.
dond is offline   Reply With Quote
Old 05-15-2015, 10:21 AM   #6
Chassis: TC/2000
Thanks for the input guys. I think I'll pass on the gas bus. Using the assumed fuel prices and Tango's estimates I got about $1,000 more expensive per 2,500 miles driven with the gas bus. Using Cowlitz's more optimistic numbers it was more like $400. I'd venture to guess that the real number is somewhere between the two.
I'll keep looking.
Old 05-15-2015, 02:43 PM   #7
Chassis: B3800 Short bus
Do you have estimated numbers for the DTA360, Cowlitz? I know a guy around here absolutely loves them. Underpowered, but supposedly they sip on the fuel likes its a 20 year Scotch.. savouring every drop
Old 05-15-2015, 07:39 PM   #8
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Your gas bus will get a solid 8-9 MPG...if you leave the engine off and push it off of a cliff. LOL. Sorry, couldn't help myself. I think the message is clear that a diesel will give you much better fuel mileage. There are so many buses out there with good engines, why compromise only to get bled dry every time you take a trip.
I'm hungry!
You Gotta Let Me Fly
Old 05-16-2015, 06:09 AM   #9
Coachwork: ward
Chassis: international
Engine: dt360a
i have that engine. got 13mpg from south louisiana to northeast oklahoma. at545 and 478 gears in 66 passenger IH bus.
Old 05-16-2015, 10:47 AM   #10
I have no personal experience with the DT(A)360.
What I have been told is it performs pretty much like the Cummins 5.9L.
I would guess it would be in the 9-12 MPG range depending on load, speed, and terrain.
Old 05-16-2015, 04:45 PM   #11
Jolly Roger's Avatar
Engine: Detroit 8.2
I have a DT 8.2 an AT 545 with an eaton rear with 6.50 gear's I have a lot of advice on how to get above 49 mph but no one will help with gear sizing and it is cheaper for me to buy the rear with the gear that I need! I have heard anything from 3/7 to 4/11?
86 ford Wayne full size. I have heard everything from start over to rip out motor to change tranny and I have been to eaton for the rear? Will anyone recommend a gear to change my rear to? Also even from eaton no one will talk to me about what rear is compatabile? The men 5-state's over will make recomendation's but won't finalize unless I bring the bus to them to evaluate? Hell all I want to do is go to texas from n.c. One time!!! just not at 49 mph? Any ideas or contacts!!!
Old 05-16-2015, 04:56 PM   #12
Engine: Detroit 8.2
I'll keep looking.
I am from Kilgore,tx and played marine and the first bus I really wanted , really wanted was a chevy gasser with a 10- speed tranny and didn't get
Cause of gas price and the wife can drive stick but 10 of them was a NO after she pushed the pedal! Dang it ! I loved everything about it and could work on every part now I have one that is teaching me more than I am it
Old 05-17-2015, 12:23 AM   #13
Engine: 190hp 5.9 Cummins
Is that the DT530?
If so, I would chose anything 4.44 and up. So 4.44 would be good for hills and mountains, but the 3.54 will be better for flat ground.
Its too bad you have that AT545. That engine is soooo under tuned because of it. If it was a standard transmission, I would go 3.54 and turn the engine way up.
Old 05-17-2015, 08:36 AM   #14
The total cost calculation depends also on the purchase price, and how much you drive. If you are going across the country, there is no question that a diesel will have a lower total cost. If you only make two round trips per year to the lake that is 100 miles away, the fuel used driving 400 miles per year may not offset other costs. It may not pay to ignore a less desirable (and therefore cheaper?) gasser for limited driving.
We used to have a 1993 DT360 box truck with a 5-speed stick at work. I'm sorry I don't remember the fuel mileage, as I wasn't paying for the fuel.
The truck required patience to drive. At full throttle, it would merge into the Interstate driving lane at 35 MPH, coming out of a tight corner onto an uphill ramp. It took about 3 to 5 minutes to top out at 64 MPH on the level. In heavy traffic, you had to look about a mile down the interstate, and change lanes before you hit a slow-down, because if you took off speed it was going to take a long time to get it back.
That being said, it would not be a bad engine for relaxed exploration of 2-lane highways through rural America, but it is not a good choice for express cruising across endless prairie on an Interstate.
"You pays your money and you makes your choice."
Old 05-17-2015, 11:49 AM   #15
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
I have gotten 8-9 mpg on my bus, a 34' Thomas pusher, 21,000 lbs curb weight, with a Diesel CAT 3126 and Allison 5 speed. This is before I enabled the 6th gear which dropped engine speed at 65 by about 300 rpm. I haven't driven it enough with that having been done to get a measurement on fuel consumption after the trans reflash. The 8-9 mpg figure is with me doing 65 mph, pedal to the floor the entire time I am accelerating and cruising.
My last job we had 2010-2014 Chevy Express 3500-based 17' box trucks (dually) with a curb weight of 9500 when empty and max gvw of 12,700. Probably a less than a bus on the same chassis would weigh. We did pickups in DC, city traffic but were also on 95 a lot. They had chevy 6.0 V8s and 6 speed autos, and with 20-something males driving them they got 7-8 mpg consistently. Highway or city didn't seem to make much of a difference as they were constantly gear hunting on the highway and downshifting to 4th on a 1% grade due to the massively terrible aero of those trucks.
So figure a pretty new engine design (old school pushrod v8 but whatever) and a good 6 speed trans and geared for hwy use, which is like mechanically a best case scenario. Even then, it only got 7-8 mpg. I would figure a bus you're buying with a gas engine would be older and have a 4 speed and a chevy 350 or big block V8 that runs less efficiently and may have shorter gearing.
I'd skip out on the gasser, just my opinion.
porkchopsandwiches is offline   Reply With Quote
Old 05-17-2015, 10:20 PM   #16
The new GM 6.0L gas V-8's with 4L80 transmissions in the cut-away buses are turning into some fairly fuel efficient power packages.
My customers report they regularly get 10-12 MPG with them.
That is from daily school routes, daily shuttle routes in town, and dairly service routes going between towns.
If I was going to get a small Type 'A' school bus or light duty commercial bus on a cut-away chassis I would chose the GM chassis with the 6.0L before I would look at any Ford chassis and I would not chose a diesel in the light duty chassis.
Old 08-03-2015, 03:22 AM   #17
Year: 97
Coachwork: Moi
Engine: 444e...7.3L
I got a triple 4/ 7.3l and i get 9.5 miles a gallon doing a max speed of 50mph. In metric thats 25l per 100 klicks doing 80 kph
rock649 is offline   Reply With Quote
Old 08-07-2015, 12:39 PM   #18
We all hate metric.
A friend calls the metric side of a tape measure the french side. Lol
Old 08-07-2015, 01:30 PM   #19
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Odd. I've the same engine, and got about 10mpg with at 60-65; including about 45 minutes of creep on the Cross-Bronx in NYC at rush hour. And my Amtran's a huge brick (3000RE) with the aerodynamics of a strip mall
Captain Obvious on deviantArt
Old 08-07-2015, 01:32 PM   #20
Originally Posted by nat_ster View Post
We all hate metric.
Not me! I'd prefer the world be SI (metric) over the arbitrary measurements of the imperial system and the US system.. Making everything base 10 is much easier for conversions. The problem is that only 90% of the world has adopted it and us North Americans live in that weird 10%. We still have some industries holding out on the metric system even in Canada. Lumber, steel, etc are still measured in inches and feet. Grocery stores typically measure in both systems.
Formula to convert 2834 milligrams to grams (milli = 1/1000, or 0.001):
2834 milligrams / 1000 = 2.834 grams
OR
2834 milligrams * 0.001 = 2.834 grams
Formula to convert 2834 centimeters to meters (centi = 1/100, or 0.01):
2834 centimeters / 100 = 28.34 meters
OR
2834 centimeters * 0.01 = 28.34 meters
Formula to convert 2834 pounds to tons:
2834 pounds * 0.0005 = 1.417 tons
Formula to convert 2834 US fl. ounces to US gallons:
2834 fl. ounces * 0.0078125 = 22.14063 US gallons
Which ones can easily be done in the ol' noggin? Once you know the order of milli, centi, deci, deca, hecto, kilo, mega, giga, tera you're good to go. All base 10.
Most of you probably already know kilo, mega, giga, tera from the computer world.. Thats half way there!
Edit: Obligatory Oatmeal comic (he's American, btw )
http://theoatmeal.com/pl/senior_year/science
