Old 09-29-2006, 12:22 PM   #1
the_experience03's Avatar
Tell them you have a GMC 6000 or a Chevy C-60 and everything should be kosher.
Your 350 is a small block. It is, however, an industrial version. Chances are the internals are all forged. Those motors are highly prized by engine builders because they're a cheap source of strong parts. The output is up or down epanding on what other 350's you look at, but they will last forever. As for specs, I'm not sure, but I'm sure if you google "industrial 350" you should get something back.
Old 09-29-2006, 08:26 PM   #2
Coachwork: Ward Genesis
Engine: DT466/MT643
Generally speaking, the HD 350 will have:
Forged steel crank with HD rods (not unlike what a high-performance engine uses...in fact, I think the 350 in the Z/28 used the same parts)
4-bolt main block, possibly high-nickel casting
Heavy pistons with thick domes & maybe an extra ring
Deep (6-7 quart) oil pan, possibly high-volume pump & oversized filter
Stainless exhaust valves with hardened seats & valve rotators
Possibly even stainless intake valves
Low compression
RPM governor on either the carb or distributor
Jarlaxle
Old 10-16-2006, 06:10 PM   #3
Zen Ken's Avatar
Low compression? <---- not as bad as it may sound. You won't have a hot rod off the line but you'll have so much torque (pulling power) you'll be able to climb trees with it!
1993 Amtran (Ward) 77 Passenger body on an International frame. DT360, Allison 545 AT. The avatar is my first skoolie, "The Rocket" may it Rust In Peace. Follow the links at the bottom to see the horrible details at http://www.gentlekharma.com
Be Amazing
Zen Ken is offline   Reply With Quote
Old 10-16-2006, 07:23 PM   #4
Steve's Avatar
low compression <-- usually will be more reliable over time too
So now I will have to drive this thing? paxye Everything Else | General Skoolie Discussions 48 10-18-2014 09:03 AM
What is the one thing you would do different? madpsalmer Conversion General Discussions 2 10-25-2010 06:23 AM
Need some Details about a mid-90s International D4E Everything Else | General Skoolie Discussions 1 03-20-2010 03:28 PM
Good thing I have a bus. Steve Everything Else | General Skoolie Discussions 2 09-24-2008 02:41 PM
Flying Pig doing it's thing...... Vern1 Skoolie Conversion Projects 0 09-18-2004 07:03 PM
