12-11-2017, 01:08 PM
#481
I gave up drag racing when it went to starter boxes. Besides the cost of those slicks isn't worth it
Sent from my LGL64VL using Tapatalk
12-11-2017, 01:09 PM
#482
We should set up some bus heats. Lo
12-11-2017, 01:11 PM
#483
Not a bike person I'm a convertible person once I restore my midlife crisis car that is. I can't even ride a moped.
12-11-2017, 01:13 PM
#484
I don't scrape angled die grinder and 3M roloc pads
12-11-2017, 01:15 PM
#485
Should be able to pull top half of the shroud
12-11-2017, 01:16 PM
#486
Cummins in it or 360?
12-11-2017, 01:18 PM
#487
More like 25 the ABS on my cressida 91 worked perfect.
12-11-2017, 01:19 PM
#488
No but if ya wanna give it a shot I have one less the cassette deck
12-11-2017, 01:23 PM
#489
Problem today is most folks depend on that smart car follow too close talk to mama on the cell eat put on makeup
#490
ECCB;'s new shorty would win the Bus heats.. 215 HP DT466 and lockup trans.. that bus gonna roll!!
12-11-2017, 01:24 PM
#491
Truckers scare me the most will ride your bumper at 65 in a 55
12-11-2017, 01:26 PM
#492
Geeks trained it for the attaboys but not the awshits
12-11-2017, 01:28 PM
#493
Hey any you know how to access your profile to edit it?
12-11-2017, 01:55 PM
#494
Yes, the "User CP" button just below the "Home" button on the left top area.
Robin
Nobody's Business
12-11-2017, 02:09 PM
#495
golfersmurf57, pleeeeeeze quote some text in your replies! I can't tell what you're talking about most of the time. I'd hate to miss a gem of wisdom just because I don't know what it is that the geeks are tuning.
12-11-2017, 02:30 PM
#496
Good it's not just me. I thought he was talking to someone that had me blocked or something.
12-11-2017, 04:04 PM
#497
Chassis: Saf-T-Liner MVP ER
after some reading, I'm convinced that either you're right about him setting the gears a bit off. The other possibility is, apparently, worn gears.
If he's cool and can fix the noise in good faith I'll have him do the engine and tranny mounts. They're a major pita on this thing and he's got everything to do the job. You CAN'T lift these engines by the oil pan. If you do you risk causing a leak and you do NOT want to change an oil pan on one of these.
Here is the issue ....
The diff, if set correctly, is the most reliable bit of the bus next to the steel wheels. They are usually set in the factory, and never need touching.
It's possible yours could have worn either by being set-up incorrectly, or by negligence from the owner.
Unless you are absolutely sure you can do that job right, it's one job best left to an experienced transmission shop. You can cut the bill by removing the axle yourself, but you are in a world of hurt if you mess it up.
Done right it should be good for a million miles. Done right, they never wear out.
Oh, and don't let that "mechanic" anywhere near it again
12-11-2017, 04:50 PM
#498
Dodge work van not bus.
12-11-2017, 05:09 PM
#499
Is the setup different? Differential gears are what they are on rear-wheel drive vehicles.
Oh yeah, I said "bus", but still ...
12-11-2017, 06:33 PM
#500
a ring and pinion is a ring and pinion.. in a van like EC's there is no 3rd member so you have to take the vehiucle to the shop.. you can just pop the guts out of it and work it on a bench like in many heavier vehicles.. and even the old ford 9 inch diff...
it comes down to the fact that all mechanical parts wear over time.. if someone tows huge weights more than what the van was designed for or at the maximum for its whole life then the gear set will wear faster.. a million miles for a consumer vehicle rear is a bit much.. 250-300k definitely likely but will usually have some wear and some noise by then...
every one ive ever worked on. was aftermarket, however the common theme was that the first run or two of the diff is the final machining of the gears.. so its necessary when brand new to set it up correctly, drive it, drain it, take it apart and measure it all again, and set it up again, fresh oil and all.. on GM 8.5's you use shims for the pinion depth and for the left / right positiuon of the carrier which is typically how the lash is handled.. incorrect lash is the mosrt common reason for noise on a newer set of gears.. and sometimes you can quiet it down on an older set ..
since his shop had it completely apart, id expect them to have Measured pinion depth and adjusted accordingly.. or told EC that his gears were shot like he asked them to..
its possible the pinion bearing was so bad that it deflected and caused excessive wear on one surface or the other..
or the shop just "wings it" and puts it back together till it "feels right" whiuch wont generally make for a quiet rear.. even the most seasoned of seasoned guys ive watched put one together are measuring depth and lash and tooth mesh pattern with paste..
