Old 08-12-2009, 04:36 PM   #1
Nachtwulf's Avatar
Chassis: Spartan (I think)
Engine: Cummins BT-6
Re: Ground roof height of average school bus?
Originally Posted by TheRUNbus
It depends in the bus. Mine is an 86 Ward international and is 10ft and I'm also wondering how much height I can add. Please let me know what you find also.
-Cheers
It depends primarily on the State you are traveling. Most states have a height limit of 13' 6" for OTR vehicles, length limit of 65', and width of 102"-108". Michigan enforces the 102" limit for buses, I'm not sure about other states. Some Western states allow taller loads, but most freeway bridges are at least 14' so anything taller usually requires special permitting. I hope this helps some. Have a great evening.
Lee
"Adversity that does not kill you can only make you stronger."
Good Lord! I must be Superman by now!!!
Nachtwulf is offline   Reply With Quote
Old 08-12-2009, 08:39 PM   #2
GoneCamping's Avatar
I believe the national standard is 13' 6" for standard interstate bridge clearance etc... Guy in the shop next to me raised their roof 20" and have had no problems with that... Keep in mind if you plan on using campgrounds, some of the more rustic places may have low hanging branches etc...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
VW Bus Grafted onto School Bus Roof - Smart or Stupid Idea? dphillips Conversion General Discussions 27 09-17-2020 10:52 PM
Great Balls O Fire (not the average conversion) C00LR Skoolie Conversion Projects 2 08-16-2009 10:18 PM
Ground to roof height of average bus PLEASE HELP! timbuk Conversion General Discussions 10 01-18-2009 11:24 AM
School bus external height (Was: bizarre double-deck bus) lapeer20m Conversion General Discussions 2 02-20-2006 01:34 PM
