Re: Guardian Generator -vs.-2 honda eu2000 good deal or not?
I have been reading some of the posts about the honda eu2000 and as I understand it generating DC and then inverting the DC to make for a stable AC output, so capt'n when you opened yours up did you happen to measure the voltage of the DC that they are using, I am thinking that connecting in the house batteries, in a pack built to the necessary voltage, you could use these generators as the inverter for your bus, leaving the engine portion of the generator off and powering up the inverter portion of the generator(s) off the batteries and when the batteries get low fire up the engine portion of the generator, allowing power to flow through the inverter and also back to the house batteries?, probably need diode protection to prevent the batteries from feeding the wrong direction in the generator but seems feasible to me, having never seen one of these gennies opened before
