06-07-2018, 01:58 PM
Hatch Hole Measurements
When the hatch is removed what are the actual dimensions of the hole?
06-07-2018, 02:03 PM
Rated Cap: 35
if I remember correctly it was 24"X24"
06-07-2018, 03:20 PM
With the holes from the screws you gotta factor in a few more inches, if replacing it is what you're planning. I think my hatches have all been Transpec.
I used 30" squares of 18ga.
06-07-2018, 03:41 PM
This works better for me as I plan on putting a piece of Lexan over the opening and then adding a 14" x 14" vent fan in the middle of the skylight. The more opening around the vent the better. 24" would only give me around 5" clear ring, a 30" hole would give me an 8" ring, more light
How far in from the edge are the screw holes? If I over lapped 1" .........Nevermind, it doesn't matter. As long as the screw holes are covered by the Lexan I'm good. Use new holes for rivets.
06-07-2018, 04:12 PM
Coachwork: Amtrans
Chassis: Genesis
Rated Cap: 20 (9 window handicap)
I did mine recently, I think with my emergency hatch removed, my hole was rounded in the corners, but closer to 25x25 than 24x24. The hatch itself extended out 27x27 on the top.
I am glad I had 2 emergency hatches, because just having a side window open and one roof hatch popped does a lot of good on a warm day before I have to kick in the roof AC that I placed in the other one.
06-07-2018, 04:14 PM
Pics?.....
06-07-2018, 04:16 PM
Two fantastic vents would move a LOT of air even on a stale day.
06-07-2018, 04:20 PM
I think vents with fans make a huge different moving down the road just to circulate the air. I want one in both ends, but don't like the thought of no more roof exit.
Crack a front window and turn on the rear fan and it will move a lot of air.
06-07-2018, 04:28 PM
You can get better roof hatch exits than the Transpec stuff that comes on the bus.
RV Escape Hatches, Trailer Hatch, Elixir Hatches
06-07-2018, 04:47 PM
I have short pockets.
But those are reasonably priced. Don't like the style much.Oops, it's the angle of the pic makes it look rectangular. $114 for a 26"x26" is reasonable. No fan, and how do get past the crank support bar on egress?
06-07-2018, 08:21 PM
$100 is cheap vs a leaky one.
They have a lever that you can easily pull that lets you get out in a hurry if need be.
Emergency Escape Vent Hatches
26" x 26" With Manual Crank Vent, White Dome & Screen, Simple Release Mechanism For Instant Escape Access, Designed For Hole Size Of 26 1/4" x 26 1/4", Includes 2" 4 Piece Metal Garnish
If you really wanted you could even add a fan and have a BIG breezy roof vent that you can climb through if you want/need.
They also have expensive boat hatches. About $300 but they're pretty slick.
06-07-2018, 09:02 PM
Ya, but I want an expensive boat hatch for $100.
I saw the quick release feature right I posted, but it wouldn't let me edit it. if I can get a vent fan in there, that might be the way to go.
06-07-2018, 11:21 PM
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
These look like they are made for flat roofs, though. The bus roof isn't flat.
06-09-2018, 12:11 PM
Coachwork: Amtrans
Chassis: Genesis
I was liking having at least one roof exit still in addition to having my AC. I've seen a few examples of people just hanging a cheap 24" box fan in the emergency exit, which I Think is the cheap way to keep the exit and still get even more ventilation out of it without spending the big dollars for a fantastic fan, some of which cost half as much as an AC.
06-09-2018, 04:43 PM
I got two NIB on ebay for $50 each. Share the link on the forum and another member got the rest.
Even if I had to pay the $140 for one I'd do it again in a heartbeat.
Its a skylight, it seals a million times better than the factory stuff, and it has a fan that uses very little battery power to run. I put one in my dodge van and can run the fan as much as I want with the van off and I've never had any battery issues. And this is still the battery that came in the van when I got it.
06-09-2018, 05:15 PM
What size and brand are they?
06-09-2018, 08:30 PM
Fantastic powered pop up vents.
Gotta be vigilant for the awesome deals. But if I were at a point whree I wanted/needed one I'd pay retail if I had to.
Some things are just worth it.
06-09-2018, 09:49 PM
Coachwork: Amtrans
Chassis: Genesis
I didn't realize how many models of Fantastic fans there are. Originally I ran across an ad for the high end fan that is $300+ which seems a bit much for an exhaust fan. I am sure you can probably find a much better price on one of the fans with less features.
06-10-2018, 05:57 AM
The basic model with a fan is just as good as the $300 ones.
For the extra $$ the expensive ones have rain sensors and wireless remotes.
