Old 04-27-2019, 01:34 PM   #1
Rovobay's Avatar
Rated Cap: 35
Headlight recommendations
I dont physically have the bus in front of me because I am at work.... on my day off....
I do have a picture of my headlights. Guess I wanna know what you bought and if you liked them. Links would be appreciated. Is this just a standard size? What size or type do I look for as I kill some time at work. At least it is overtime and will give me some money for the conversion. Cheers
My Build: https://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 04-27-2019, 01:48 PM   #2
They are a standard size 7" x 6".
Old 04-27-2019, 03:24 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Hella Conversion Headlamp kit
Old 04-29-2019, 10:35 PM   #4
OrionsComfortBus's Avatar
Coachwork: International - AmTran
Engine: DTA 360
Rated Cap: 25,500 lbs
IMO you have three options as far as replacements. Go with standard sealed beam, those last about a year or so before starting to dim. Go with L.E.D. headlights, these are great flood/short distance lights. But also be aware that you are also blinding oncoming drivers . . . even on low beam. Go aftermarket. I personally went to Headlight Revolution. Got a nice set of glass front headlights that use a H4 (i think) for about $65 plus bulbs. They are not fancy but more than sufficient. Also they are DOT approved.
What I got ( https://headlightrevolution.com/visi...h6054-5x7-7x6/ )
The price of freedom is eternal vigilance. - Thomas Jefferson
Ongoing project of maintenance and replacement of things in and on the Comfort Bus https://www.skoolie.net/forums/f9/up...bus-24772.html
OrionsComfortBus is offline   Reply With Quote
Old 04-29-2019, 10:43 PM   #5
Dog Rescuer's Avatar
I bought these:
https://smile.amazon.com/Rectangle-H...gateway&sr=8-3
LED School bus headlights - Amazon.com- I have had them for two years. They work great. I have never blinded oncoming traffic.
They are about $45 for a pair.
- Roger (Dog.Rescuer)
Dog Rescuer is offline   Reply With Quote
Old 04-30-2019, 10:12 AM   #6
Rovobay's Avatar
Rated Cap: 35
Nice everyone. Thanks for the many options.
Old 05-08-2019, 09:24 AM   #7
Year: 2006
Coachwork: Collins
Chassis: Chevrolet Express 3500
Engine: Duramax
I'm very happy with the Truck-Lite LED units I'm running. The put a lot of useful light down the road and are made by an actual OEM so the quality is consistently good.
dazdconfsd is offline   Reply With Quote
Old 05-12-2019, 02:49 AM   #8
What size (ours are 7x5 ... H6054's) and how much did the Truck-Lite LED lights cost?
Old 05-12-2019, 12:06 PM   #9
Year: 2006
Coachwork: Collins
Engine: Duramax
I'm using those, model 27450C. I used a coupon on ebay to bring the cost down to ~$300. Not cheap, but made in the USA by an OEM so not terrible either.
Old 05-12-2019, 04:31 PM   #10
Ah, thank you for the part number and price point.
I called the local Truck Pros and they wanted $239.00 each, they did not say which model it was for which they were quoting that price.. $300.00 for the pair is a little more bearable. Of course, I would have liked them for $200.00 ... dreaming.
Old 05-12-2019, 06:04 PM   #11
Year: 2006
Coachwork: Collins
Engine: Duramax
I would have liked cheaper too, and there are now knock offs on Amazon of them. The official ones are $340/pair there if you are more comfortable using that platform.
Legit looking pair
https://www.amazon.com/Truck-Lite-27...dp/B01B1SACFC/
Old 05-13-2019, 12:42 AM   #12
Legit looking pair
I found that listing on Amazon right after I sent my last message. Still quite a price.
In your opinion, is the beam patern and luminocity really good with the Truck-Lite LED lamps? Worth the price?
Old 05-13-2019, 02:17 PM   #13
Year: 2006
Coachwork: Collins
Engine: Duramax
On all 3 vehicles I put them on, they made a huge difference. One thing to keep in mind is the cut off is pretty good so aiming them well is very important. When that's done I can see quite a distance on low beam and what feels like a solid 1/2 mile on high beam.
The one area the light isn't the greatest, is the few feet directly in front of the bumper. I barely notice it from the drivers seat, but on a flat front bus you would probably notice it more. It could easily be solved with some cheap fog lights.
Old 05-13-2019, 03:31 PM   #14
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Are they glass or plastic?
Seems like a lot of $$ if comparing it to Hella or Rampage, but don't know full specs...
Old 05-13-2019, 05:42 PM   #15
Year: 2006
Coachwork: Collins
Engine: Duramax
I didn't see a Rampage link, but the Hella link earlier in this thread only converted to a H4 bulb. That should put out a bit more light, but the LED will put out far more IME.
Full specifications are available here
Complex Reflector, 5"x7" LED Rectangular, 2 Diodes Headlight, Polycarbonate Lens, E-Coat Aluminum, 12-24V | Truck-Lite
I think that for an OEM (they supply custom housings for OTR trucks) solution that's made in the USA with a 3 year warranty that might actually be worth something, they're not out of line price wise.
Old 05-14-2019, 12:38 AM   #16
Thank you for your assessment. After all, that is what I asked for.
