Old 02-20-2018, 10:50 AM   #1
Exclamation Headroom, how much at the walls?
So the bus I am looking at (remotely - can't physically get to it yet) has 78" of headroom, what would the height be at the side walls? 6" lower? 3"? Its a 2001 Thomas MVP-ER
sparq is offline   Reply With Quote
Old 02-20-2018, 11:10 AM   #2
Chassis: Saf-T-Liner MVP ER
Lemme go measure for ya ....
It's raining out, but I'm back ...
It is 60" from the OEM plywood to the top of the window frame, and the rib starts to curve 3" above that.
Hope that helps.
Steve Bracken
Build Thread
Old 02-20-2018, 12:11 PM   #3
Hope that helps.
AWESOME
Old 02-21-2018, 08:20 AM   #4
Hope that helps.
Would you by chance be willing to take another measurement for me? On the exterior, from the bottom of the window to the rub rail thats at the top of the wheel height? (not sure if the amount of rub rails varies on these or if they only came with this one) -- THANKS IN ADVANCE!
Old 02-21-2018, 04:48 PM   #5
Bottom of window to top of that rub-rail is 30 1/2"
Drip rail (top of window) to that rub rail is 58"
Steve Bracken
Build Thread
Old 02-21-2018, 05:26 PM   #6
:highfive:
