Old 10-06-2012, 10:17 AM   #1
lornaschinske's Avatar
Rated Cap: 89
Heat Grabber Solar Hot Air Collector
I made a "fast & dirty" Heat Grabber for the bus over the past two days. We have a cold front moving thru this weekend and I wanted to get it up and running. So of course it is very over cast today!
Oh well. I did get a lot of the measurements worked out. It's all built out of scrap and held together with elastometric caulk. If this works well, I will build a couple of permanent units out of more durable materials... not 1/8" luan. Building the temp unit helped us see how we need to modify the unit to fit into the window a little better. I need to figure out how to attach it to the side of the bus. It was such a pain to install in the window, I think I want to mount it to the sides of the bus securely enough to survive a trip down the road (BTW, glazing is bus safety glass from the side windows).
Just waiting for a cold sunny day now!
Fulltime since 2006
Old 10-06-2012, 11:53 AM   #2
Re: Heat Grabber Solar Hot Air Collector
I hope they work good enough to help you, I have read a lot about these units and its very interesting
Old 10-06-2012, 12:44 PM   #3
Rated Cap: 89
That's why I am simply "testing" one before I sink more $$ into building two (or three) for "keeps". I have a total of 4 BB glass pieces on hand. So that's 4 heaters I could build. I hope the sun comes out tomorrow (while I'm at work) to see if this thing works. If it does, it could save us quite a bit on daytime LP/electric heat. I'm just a little concerned over the small size of the one I built (25"). Is it too small or do I need to make it longer. This is what I am testing.
Fulltime since 2006
Solar Water heat Sojakai Alternative Fuels | Electric, Propane, Wood Gasification, etc. 5 12-30-2013 08:43 AM
Solar ovens and solar water heaters/showers tomas_maly Heating, Cooling and Appliances 6 05-22-2013 11:43 AM
no heat mfrederick Skoolie Conversion Projects 6 01-11-2010 09:05 PM
HEAT phillbus914 Heating, Cooling and Appliances 27 03-07-2008 12:38 AM
I need heat! the_experience03 Conversion General Discussions 8 02-18-2006 08:28 AM
