Old 03-04-2016, 10:14 AM   #1
Chassis: Bluebird
Engine: Cummins
Rated Cap: 73
Heat source
Hey again, my landlord just told me that my wood stove wasn't allowed, I live in a real cold place, can anyone recommend a good propane heater or furnace that would work well in negative 20 f
toasterman12 is offline   Reply With Quote
Old 03-04-2016, 10:37 AM   #2
Rated Cap: 40 Prisoners
The Mr Heat has both radiant and convection heat, I would go with the 18000 BTU unit.
Old 03-04-2016, 01:14 PM   #3
Chassis: TC2000 RE
Engine: 8.3l Cummins
Make sure you figure out a way to deal with the moisture. Mr. Heaters work great and are safe, but dump a bit of moisture from the propane into the environment.
aaronsb is offline   Reply With Quote
Old 03-04-2016, 04:01 PM   #4
what works for us.
We live in a fifth wheel, not a bus, but we've had pretty good luck with electric heaters. We use the kind that have a low wattage setting (750 watts instead of 1500) so we don't overload the circuits. They're hooked up through a thermostat (available at any home improvement store - either mechanical or electronic). Three or four heaters are all we need. We were careful not to get two heaters on one circuit breaker. Just be sure not to leave things laying in front of them.
dadelay is offline   Reply With Quote
cold climate, furnace
