Old 04-18-2018, 02:18 PM   #1
SilentReprieve's Avatar
Chassis: HDX
Engine: 3126 7.2
Height of Ole' 41....NOW WHAT??
So I have a 24 X 48 Pole barn heated with a beautiful cement floor.. Been planning on bringing the bu home pulling her in and ripping her down... My door is pretty big and definitely wide enough to accommodate...Or so I thought...Its 9'6" and if I took the door off and put a barn style set of sliding doors its at 10 ish...phew I may just make it...
Well wouldn't you know from the paperwork Thomas bus sent me and the info they shared, The bus stands at 123" from ground to top of emergency hatch..All sounds good right?? well no... 123 inches is 10'4"... So I guess unless I take the air from the tires and it squeezes in I may not have that option anymore...I guess I could get smaller tires and rims, A scrap set or whatever.. But that is something more I'd have to have laying around only to part with them later anyways.. Not to mention more money to spend on something getting thrown away..
Any ideas??
"Fitting a bus for your lifestyle is certainly easier than fitting your lifestyle into your bus" The journey begins... I am expecting a rough road ahead!!
Jim, Marion NY
SilentReprieve is offline   Reply With Quote
Old 04-18-2018, 02:23 PM   #2
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Don't know the building style but can you lift the header for a taller opening if you are going to change doors anyway?
Whatthefak is offline   Reply With Quote
Old 04-18-2018, 02:37 PM   #3
Chassis: HDX
Engine: 3126 7.2
Well The door change was an idea but also wont allow it to happen... I am letting the bank have their house back ... think they'd mind if the pole barn was missing the headers and doors? hell for that matter the heat too...
My only option is to lower the height of the bus by however many inches it has to be to assure no hitting the roof...
Jim, Marion NY
Old 04-18-2018, 02:50 PM   #4
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Got enough clearance you can drive it in on a set of junk rims? That'd get you the inches you need as long as you're not dragging the bus on the ground
Old 04-18-2018, 02:56 PM   #5
Chassis: HDX
Engine: 3126 7.2
this is a good idea, compared to destroying the barn or bus... This may work... I wonder if the height includes the air ride at full pressure..
Jim, Marion NY
Old 04-18-2018, 05:12 PM   #6
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Idk about busses but I worked in a truck shop height is full air ride height
Old 04-18-2018, 06:36 PM   #7
Ronnie's Avatar
Engine: 345 international V-8
?? does this bus have air suspension? If so then just let the air out of the air bags. Should have a valve somewhere for this. Trucks do
Old 04-18-2018, 06:53 PM   #8
Chassis: IH
Is that height with the hatch open or closed?
If it's air ride, deflate the air bags - detach the control arm to do this if needed.
Deflating the tires is another possibility, though I would do this as a last resort.
Old 04-18-2018, 06:56 PM   #9
Chassis: Saf-T-Liner MVP ER
Whatever solution you come up with, don't get it in the barn then do a roof raise
Steve Bracken
Build Thread
Old 04-18-2018, 09:49 PM   #10
Jdawgsfanasty's Avatar
[emoji23][emoji23][emoji23][emoji23][emoji23][emoji23]
Jdawgsfanasty is offline   Reply With Quote
Old 04-18-2018, 10:34 PM   #11
Chassis: HDX
Engine: 3126 7.2
oh that is promising....
Jim, Marion NY
Old 04-18-2018, 10:35 PM   #12
Chassis: HDX
Engine: 3126 7.2
closed
Jim, Marion NY
Old 04-18-2018, 10:36 PM   #13
Chassis: HDX
Engine: 3126 7.2
[QUOTE=Twigg;264718]Whatever solution you come up with, don't get it in the barn then do a roof raise [/QUOTE
aww Twigg... you take the fun out!!....
Jim, Marion NY
height, roof, thomas, tires
