Old 10-21-2015, 10:49 AM   #1
Hello and help?
Hello all, shopped around and this seems to be the best place to get Edjamcated. I was in the truck repair business for my earlier life, but been away about 15 yrs. I recently bought a 2001 FS65 Thomas with the ISB 5.9 with a recent rebuild injector pump and updated primary pump. Had someone locally go listen to it, as it was 100 miles away, and I bought it after he heard it run. I was buying for the engine, but might keep and convert. It's a short (35 pass?) with wheelchair lift. I took the vin to freight liner dealer asking to buy a build sheet and they said they couldn't do that😞. Is there a place to get a real build sheet? I ran 4UZ3CFAC71CG89517 in a decoder and basically just gave me the engine size. I'm assuming it has an AT545 but hold out a touch of hope it has a 2000 instead. I am also a bit confused as he sent me picks and I see a hydroboost master cylinder but there is also an air compressor on the engine. Any help in answering some questions, and better yet, getting a build sheet would be greatly appreciated!
Thanks
Brett Baker
Mrbrettbaker is offline   Reply With Quote
Old 10-21-2015, 01:32 PM   #2
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
[QUOTE=Mrbrettbaker;126998 I took the vin to freight liner dealer asking to buy a build sheet and they said they couldn't do that😞. Is there a place to get a real build sheet?[/QUOTE]
Check your local Thomas dealer.
Captain Obvious on deviantArt
