Old 04-07-2005, 06:53 AM   #1
highway speeds/mileage?
I own a 86 international/bluebird/ 65 pass, conversion, 6.9l diesel auto, 95,000 miles, what kind of speed should i be able to get on the highway? i can only get about 65 on a good windy day ( wind behind) down hill, being towed by a yugo!, the "motor home" has tons of power in the city, motor is in great shape, good oil pressure, good compression knock, trans works great,
is there a speed limitter on these buses? or something?
also i was wondering what kind of mileage i should get on the highway?
also, here is a link to check out some pics of it as well as some atv's
http://home.comcast.net/~atvmisfits/home.html
1987 ihc 60 pass bus, converted to toy hauler, 6.9l diesel, auto, sleeps 6, carries up to 4 atv's
frogee is offline   Reply With Quote
Old 04-07-2005, 05:58 PM   #2
Your rear end gears will determine what speed you will get on the highway. If you are able to get up to 65 that is good. Most skoolies will top out at 50-55. If you change out the gears you could top out much higher.
busone is offline   Reply With Quote
Old 04-08-2005, 11:52 AM   #3
trx
trx's Avatar
Chassis: Chevy C-60
Engine: 8.2L Turbo Detroit Diesel
Send a message via ICQ to trx
I know the 6.9's are known for their lack of power. Higher gears might work but that's if you are maxing out more on RPM and not power. Hopefully others with 6.9's will speak up if they've tried re-gearing. I'd like to do it with my bus (8.2T Detroit), mainly to drop the RPM's and gain a bit of speed. I can run 63 mph to the floor but I prefer the RPM's at 60 and it can hold 60 up most hills.
trx is offline   Reply With Quote
How to tell if a bus is geared for highway speeds opus Conversion Tutorials and How-to's 4 07-22-2012 02:31 PM
Can a transit bus be made to go faster for highway speeds? lornaschinske Mechanical and Drivetrains 5 04-16-2012 10:29 AM
Throttle Sputter at high way speeds jaredg Mechanical and Drivetrains 3 11-04-2011 10:51 PM
Best type of bus for highway usage... Flannel Conversion General Discussions 3 05-27-2011 08:26 PM
Havoc on the Highway the_experience03 Skoolie Conversion Projects 11 06-27-2006 09:18 PM
