Old 10-19-2008, 11:50 AM   #1
TikiBus's Avatar
Year: 92
Coachwork: Amtran Genesis
Engine: International DT466
hooking air compressor hose to air tank?
I'd like to hook an air compressor hose with a valve to my air brake tank line, to use while I am sitting still. Would this create a problem with the workings of the compressor, brakes, ect.?
TikiBus is offline   Reply With Quote
Old 10-19-2008, 02:57 PM   #2
Re: hooking air compressor hose to air tank?
NOT AS LONG AS YOU HAVE A SEPERATE VALVE FOR IT, OUR FIRE TRUCK HAVE A AIR CHUCK ON THEM THAT FEEDS OF THE BRAKE SYSTEM
fireman69 is offline   Reply With Quote
Old 10-19-2008, 07:44 PM   #3
the_experience03's Avatar
Just tap in at the tank drain and make sure you have a valve for it. Most fittings are 1/4 NPT I believe.
Old 11-02-2008, 09:10 PM   #4
Yeah it wouldn't be a bad idea anyway to put a chock on there. If the motor doesn't run you can hook up a compressor to keep the brakes pressurized when towing. Unfortunately I have a lot of experience being towed.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Hooking up air hose / air tool to the air break compressors? GoneCamping Conversion General Discussions 28 09-11-2017 07:14 AM
Hooking up the heater to a second radiator? Steve Conversion General Discussions 3 07-12-2009 09:24 AM
Viton hose best way to go? SoulFire Veggie Oil | WVO | Biodiesel | SVO 3 11-29-2008 08:26 PM
Need advice for hooking up my electricity Shrtbusdrvr Conversion Tutorials and How-to's 9 07-17-2007 10:10 PM
Hooking up stereo Chfsfn2 Conversion Tutorials and How-to's 1 08-31-2004 10:09 AM
