Old 08-10-2006, 02:03 AM   #1
How do I find out my exact engine?
Id like to know as much as possible about my Bus. As of now I know its a 1986 S1700 International Thomas Built "short bus". 6.9LD 8cyl engine, AT545 transmission.
Basically I want to know what exact engine I have in this thing.
ParadigmCrime is offline   Reply With Quote
Old 08-10-2006, 09:19 AM   #2
short bus
is that a deisel in your bus.? i got a 345 gas v8 in my 81 s-series short bus. its about a 21 footer. 5 window, 6 if you count the drivers window. oh, its a international / wayne life guard body. got the 1800 loadstar chassis. has 22.5 inch rims on that thing. im heading to the big dmv this morning. be a slow ride cause shes low geared ,but whats the hurry i guess. does your bus got the truck style front end and chassis or is it the van type???? gotta go, westport-wayne
westport_wayne is offline   Reply With Quote
Old 08-10-2006, 03:40 PM   #3
lapeer20m's Avatar
6.9 liter diesel if i'm not mistaken is the same diesel engine that was used in ford pickup trucks prior to the 7.3 liter power stroke
iI believe it's a non turbo, mechanically injected v8 diesel built by international .
It's not to be confused with the inline 6 cylinders DT series international motors however.
Old 08-10-2006, 06:22 PM   #4
Yep, its a non-turbo mechanically injected v8 diesel built by international.
I was more looking for the size of the engine though.
Old 08-10-2006, 09:22 PM   #5
Engine: 7.3 diesel
Do you mean like? 420ci
Old 08-10-2006, 09:58 PM   #6
the_experience03's Avatar
6.9 liters IS the displacement :P As long as I'm working on my personal WVO conversion, I thought I should throw in that your engine utilized indirect fuel injection which is thought to be better than direct injection should you choose to run veggie oil. Of course direct injection tends to have more power and cleaner emissions which is why you see most modern diesel utilizing this system.
Old 08-11-2006, 12:56 AM   #7
I do run veg oil, I just drove about 4200 miles on veg oil all over the US. Bought it in Asheville NC, and drove it all through the south, and eventually back to california. Spent maybe 120 dollars on diesel in some tough spots.. but I did over 4000 miles in veg oil.
Old 08-11-2006, 10:19 PM   #8
Do you use onboard filtering? I don't mean to hijack your thread, but as long as you're probably watching this one.....
My filtering set up is onboard, but seperate from the actual fuel tank. My hope is to be able to filter 8 gallons per hour in order to maintain a steady travel rate. Perhaps I need to just post a picture....
Anyway...I have "dirty" barrels in back, a dirty tank feeding the heated filtering system, a clean tank below that, and then a final seperate tank for the actual engine. My hope is to make 5000 miles in 10 days on veg oil.
Old 08-12-2006, 05:21 AM   #9
Im working towards that type of system, but for thhe most part. I was just collecting it, and pouring it through filters into the tank, and also had a dirty barrel I would fill, and then later filter into the tank if need be. The system is really.. how would I say on-the-whim/fly, because its what I had to work with. However now I got it back to where i can work on it, and make it how I want.
Possible to replace engine with larger engine? Alexlorraine01 Conversion General Discussions 4 04-22-2014 05:22 PM
How do I find out what engine I have? Skip GM | Chevrolet Drivetrain 3 01-03-2014 10:19 AM
Dog Nose vs. front engine vs. rear engine? dgorila1 Conversion General Discussions 20 12-21-2011 06:40 PM
Rear engine VS Front engine (TC Style) BBTC2K Conversion General Discussions 2 12-02-2009 10:25 PM
Replacing Gas engine with Diesel engine question ? soused moose Conversion General Discussions 7 03-17-2005 08:15 PM
