Old 09-10-2007, 04:35 PM   #1
odyssess's Avatar
Engine: T444E 3800
How does the engine diagnostics button work?
On the dash I have a button marked engine diagnostics, but it doesn't do anything when I push it. It's a 1996, does anyone have any ideas?
http://www.skoolie.net/gallery/v/Skooli ... Green+Bus/
Keep on Keeping on.
odyssess is offline   Reply With Quote
Old 09-10-2007, 11:33 PM   #2
Engine: 7.3 diesel
Re: How does the engine diagnostics button work?
I think one thing it does is to shut the oil change light off. I thought it was something along the lines of turn key to on position and press 3 times and on the third time hold it until the light goes out or something. I'm sure it does more than this but I don't know what.
Old 09-12-2007, 02:19 PM   #3
rereid's Avatar
Engine: DTA360
Hold button down,turn key to ignition,release button.The yellow check engine light will now blink out all 3 digit active codes.The red stop engine light will blink and then all 3 digit inactive codes will be displayed.
Turn off ignition and press the switch down,turn on ignition,pump accel pedal 3 times.this will clear all inactive codes.
International Mechanic
rereid is offline   Reply With Quote
Old 09-14-2007, 12:28 AM   #4
odyssess's Avatar
Engine: T444E 3800
Cool, you obviously know what this is, can you explain what the codes are or what they mean? How can I use this? Thanks man.
Keep on Keeping on.
Old 09-15-2007, 09:08 AM   #5
Coachwork: Ward Genesis
Engine: DT466/MT643
Any Intenational dealer can get you a code chart & a troubleshooting flowchart. It's actually pretty user-friendly.
Jarlaxle
What it this button for? (and some weird noises) gbstewart Conversion General Discussions 8 03-17-2011 01:59 PM
Mystery button and "batteries" toggle switch GameRV Electrical, Charging and Solar 4 12-05-2010 01:48 PM
fast idle switch diagnostics frank-id Cummins Drivetrain 2 05-21-2010 12:42 AM
Rear engine VS Front engine (TC Style) BBTC2K Conversion General Discussions 2 12-02-2009 11:25 PM
Replacing Gas engine with Diesel engine question ? soused moose Conversion General Discussions 7 03-17-2005 09:15 PM
