Old 09-04-2017, 09:14 AM   #21
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
Sorry you cant get a definite answer so please take my advice and find a certified mech at a cummings shop or call them
mmoore6856 is offline   Reply With Quote
Old 09-04-2017, 11:09 AM   #22
i think the problem is everyone seems to have a strong opinion on it..
some guys will tel lyou that your engine is ruined if you idle it 3 hours.. and others are of the mind that you can idle it forever...
the common denominator seems to be temperature... my 444E has a placard right on the dash telling you to crank the speed up to idle in cold weather.. (or with the updated ECM software it will automatically adjust itself accordingly to stay warm)...
ultimately it comes down to make sure you dont extract too much heat.. at a slow idle with a viscous fan clutch you are likely to always cool your radiator down to where the thermostat must close.. (unless its really hot).. with an electric clutch you likely will keep your engine close to the top of its operating range as the fan will cut off completely..then kick back in as needed..
I dont know which your bus has in it.. or maybe you have air shutters...
you can contact a dealer as mentioned and see what they say..
at a minimum you need to keep your engine warm.. you'll have a darn good shot being that its warm outside and you wont have interior heaters pulling off engine heat...
Old 10-30-2017, 10:31 PM   #23
mauricebonner37's Avatar
I have a 2003 international school bus how long does it is to idle it does it all by itself for a long time sometimes
Sent from my Z718TL using Tapatalk
mauricebonner37 is offline   Reply With Quote
