Old 03-20-2018, 05:28 PM   #1
How’s this look?
Is this right with the corroseal?
CDB5F952-6E14-4A69-AFFA-AA87E3C2549A.jpg   220665DC-A103-4571-B798-7E5BCD81E784.jpg   37002984-1DC2-42D1-A533-792EDB55AD3C.jpg
Lherrlinger is offline   Reply With Quote
Old 03-21-2018, 05:52 AM   #2
thrifty1's Avatar
Engine: DTA360
I’m curious, did you remove the floor sheet metal up to that point? If so, why not just replace that last section instead of hedging the bet on corroseal? Did you get the underside with corroseal as well?
thrifty1 is offline   Reply With Quote
Old 03-21-2018, 08:41 AM   #3
Hey thrifty, yea I did the front had some holes so I bought two new sheets of metal but the back wasn’t very bad I have put corroseal on everything that’s rusted except a couple things underneath which I will get to when the weather gets better. Going to lay the two new sheets down glue /bolt them in and then place sub flooring in.any suggestions? Comments I’m about to go to the shop and start working.not sure if I’m going to put insulation down because I don’t want to lose headroom
Old 03-21-2018, 08:45 AM   #4
Also can I see a pic of your bus I ride mtn bikes right up the road from you all the time in pisgah
Old 03-21-2018, 11:35 AM   #5
thrifty1's Avatar
Engine: DTA360
Oh my bus is pitiful man I’m just in the beginning stages of conversion. I’m just in the robotic welding trade and know a little about metallurgy thats why I was asking, more for brainstorming really. You can go laugh at it in the “92 Thomas vista conversion” thread.
There’s my worst spot so I feel you!
Old 03-21-2018, 11:36 AM   #6
thrifty1's Avatar
Engine: DTA360
And pisgah is beautiful I’m right over the sc line... need to make time to visit there again it’s been a while
Old 03-21-2018, 12:36 PM   #7
Ouch! That looks like some fairly serious rust. How are the supports and frame?
Old 03-21-2018, 01:29 PM   #8
thrifty1's Avatar
Engine: DTA360
Rest of the bus is great except this particular spot. Supports are also good except one pictured. Nothing a Hobart 140 sheet metal and some square tube can’t fix. ;) seriously though there is a tar coating on most of the bus underside just looks like it was particularly worn in this spot. Sorry for the thread jack
Old 03-21-2018, 02:17 PM   #9
People are so scared of a little rust as long as the frame is good hard work and a little metal can fix anything here’s a before and after of my floor for a little inspiration ( not that it’s that good) .im lucky to have a couple buddies that are super mechanically inclined
6229CD41-84E8-4223-BE57-32519639CA98.jpg   C9F01A6C-2D2E-48AF-A699-BCCE8C4C7486.jpg   99AA84F0-AF8F-4BFA-825F-8A101D341DBC.jpg
corroseal, floor, floor prep, floor replacement
