Old 08-22-2012, 09:09 PM   #11
lornaschinske's Avatar
Rated Cap: 89
Re: How to tow a car AND a boat?
Originally Posted by nat_ster
... Trust me, you don't want to be trying to pull a car with a tow bar behind a bus. The rear swing is far too great from the length of the overhang on the rear of the bus. It would drag your car sideways, and, or break something.
We towed our Jeep Grand Cherokee, 4 down, 1700 miles from NC to NM. No problem (until David forgot to put the Jeep's tranny in Neutral). I was behind David a great deal of the way and the Jeep pulled just fine.
Fulltime since 2006
Old 08-23-2012, 11:03 AM   #12
Engine: 190hp 5.9 Cummins
Just because you did it, and it seemed fine, doesn't mean it was. Your Jeep is a little bigger, and a lot stronger than a car. Your schoolie on a tight turn would drag the front tires of the jeep side ways and you would never know.
Again, I drove a Truck with the same wheelbase, overhang, ect. I've seen it happen.
The only way I can think of to correct that, would be a tow bar as long as the overhang on the bus. That would cancel out the swing. But for what the op wanted, this would make the over length problem worse.
Posted for educational purposes only.
Old 08-23-2012, 02:38 PM   #13
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
always this option
Old 08-23-2012, 03:07 PM   #14
GreyEagle's Avatar
http://rv-roadtrips.thefuntimesguide.co ... wing-2.php
Hereís what you need to know before you pull 2 trailers behind your RV.
These are just some of the things to keep in mind about triple towing:
Triple towing isnít legal everywhere; every state is different.
There is usually a maximum length requirement, which varies between states.
Backing up with such an arrangement is near impossible; donít even try it.
Donít exceed the CGWR (Combined Gross Weight Rating) of your tow vehicle.
Make sure all portions of your combination have the proper safety equipment in place.
Check your state & local requirements if you must tow more than one... behind you tow vehicle.
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 08-23-2012, 03:16 PM   #15
Rated Cap: 89
I thought my Jeep was a car (or a tractor depending on how I used it). The front tires track behind the bus. If they were being dragged sideways, wear would have occurred on the tires and they would have been hotter than normal. We kept an eye on the tires of all the vehicles, especially the ones being towed. Of course the only tight turns were in the Benbrook COE (Holiday Park... nice little campground... $28/night for w/e, no sewer just dump station... skoolie friendly of course). David turned the bus & jeep around in the empty parking lot at the boat launch. If the tires had dragged, we would have seen evidence of it in the loose sand/gravel that accumulated on the surface of the pavement. We also would have blown a tire out in a very few miles. How do I know this? Because David put "R"-Jeeps tranny in gear while we were at Benbrook (spent a couple nights there). He didn't mention this to either Stacey or me, so we assumed (never assume) the Jeep was still set up to be flat towed when we pulled out on Monday. From Benbrook COE to the exit where the front tire blew from being towed in gear (tires rolled but with a great deal of resistance) was roughly 20 to 25 miles. Gotta love that there seems to be a Wal-Mart at every other exit! But you are probably right. We can't pull the Jeep 1700 miles behind the bus. Can we pull the single axle food cart behind the bus? I just need to know because if we can't, then we didn't pull the cart over 150 miles on Hwy 380 back in December.
NOTE: That white stuff is NOT snow because it "hardly ever" snows out here. AND "IT MELT'S OFF BY NOON!"
Fulltime since 2006
Old 08-23-2012, 03:24 PM   #16
GreyEagle's Avatar
then we didn't pull the cart over 150 miles on Hwy 380 back in December....lol
Didn't think that was you guys we seen on the road, it just looked like your bus and food cart going down Hwy 380...
GreyEagle
Roll - On...
Old 08-23-2012, 03:37 PM   #17
Rated Cap: 89
I "photoshopped" the pics!
Fulltime since 2006
Old 08-23-2012, 08:13 PM   #18
Back to the original point, the Better way of doing it.
Rules for different areas including Canada.
http://www.woodalls.com/articledetails. ... 1195129#AL
Open model.
Closed in model.
Just make the bottom one your boat.
I would also run a single 22.5 tire on each side that matches the tires used on the bus, not them tiny things.
Old 08-23-2012, 09:18 PM   #19
I just found this.
Where it came from.
http://www.hardcoresledder.com/forums/3 ... ailer.html
Old 08-23-2012, 09:44 PM   #20
bus-bro's Avatar
Engine: 3208 na boat anchor
How the heck do you launch the boat?
BUS/BOAT ol trunt Everything Else | General Skoolie Discussions 4 11-03-2012 09:50 AM
It's a boat, but ... wtd Conversion General Discussions 5 12-03-2011 12:01 PM
Skoolie Boat busdriver_phil Everything Else | General Skoolie Discussions 2 09-03-2010 08:01 PM
Bus Boat House nyrockingchairs Everything Else | General Skoolie Discussions 2 07-20-2007 01:35 PM
School Bus as Boat soused moose Everything Else | General Skoolie Discussions 12 03-03-2006 12:27 PM
