Originally Posted by cowlitzcoach
Not a bad looking little bus for a reasonable price.
Injector issues are not unknown for that engine, particularly one with that many miles. I would first try running some fuel conditioner through and changing the oil. The injectors work on high pressure engine oil. If the oil is dirty or the wrong viscosity the injectors won't work properly. The injector tips could be clogged up due to old fuel and not running very much recently.
In other words, before you spend a bunch of $$$ doing some major repairs do a little regular maintenance and then get it out and drive it a bit. It just might clear itself up.
The flat floor is a real plus and it appears to have rear air ride suspension which is another big plus.
The smaller 8-lug wheels and tires are a bit uncommon and will limit your tire choices. Limited choices means the tires will cost more than tires for a big bus--common=less expensive, less common=more expensive.
The seats with the inserts in them are built in booster seats. Pull down the insert and you will discover they are pretty much the same as the booster seats found in some Chrysler/Dodge/Plymouth mini-vans.
So yes, I think you got a pretty nice bus at a very affordable price.
I am looking forward to this project. gonna do just the bare minimum at first. insulation, no holding tanks for the time being. I am thrilled with the booster seats for my 7 and 3 year old. I will keep 2 seats to make a dinette.
Good call on the maintenance. I will run some seafoam through it. I will get all the service records too.
I want to research possibly lifting the rear end a bit so I can get larger tires on it. the front would accommodate a larger tire without lifting it.
