Old 12-02-2008, 01:00 AM   #1
Year: 1978
Chassis: INTERNATIONAL
Engine: 345CU GAS
Rated Cap: 55
I HAVE A SMALL (27 FOOT)BUS TO HEAT
I'M NEEDING ADVICE ON A WOOD BURNING STOVE TO HEAT MY 27 FOOT BUS.I FOUND A GREAT ONE AT NAVIGATOR STOVE WORKS,THEIR LITTLE COD MODEL...MY BUDGET WON'T ALLOW THE PRICE THOUGH.NEXT OPTION IS ONE MADE BY THE FOUR DOG STOVE COMPANY IN ST.FRANCIS ,MN.THE 2 DOG MODEL LOOKS TO BE ONE THAT WOULD FIT MY NEEDS.IS THERE ANYONE HERE WITH FIRST HAND EXPERIENCE WITH THIS STOVE OR OTHERS REASONABLY PRICED ?THANKS IN ADVANCE TO ALL REPLIES.
ROLLINGHOME56 is offline   Reply With Quote
Old 12-03-2008, 06:17 PM   #2
Year: 1978
Engine: 345CU GAS
Rated Cap: 55
Re: I HAVE A SMALL (27 FOOT)BUS TO HEAT
ISN'T THERE ANYONE ON HERE WITH EXPERIENCE IN THIS AREA????
Old 12-03-2008, 07:24 PM   #3
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Yup, that thing will heat your bus, no problem. Just be safe -- secure it well, install some heat shielding between it & nearby walls, and provide outside combustion air via an open window or vent. This is a well-done subject, so using the search function to look at previous discussions will give you a lot of info.
Lastly, typing in ALL CAPS makes your message less fun to read.
Hope this helps, and welcome to the site
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 12-04-2008, 11:39 AM   #4
recycler's Avatar
Year: 86
Coachwork: Thomas saf-t-liner
Rated Cap: 40
You might research foldable stoves. While they are not bomber they will haet your bus depending on what insulation work you've done. The best part is they can be easily stowed away when its not cold and they don't weigh a ton. Alaska stoves is another Idea. Some of the foldable stoves are actually made to cook over as well with a hot plate area on top. These stoves also don't require more that a minimal stove pipe diameter. Every inch counts in a shorty.
recycler is offline   Reply With Quote
Old 12-10-2008, 04:53 PM   #5
Year: 1978
Engine: 345CU GAS
Rated Cap: 55
Thanks for all the responses.I will post my decision/progress.....
The 72 foot 1994 bluebird/fleetwood motorhome Chadluc Skoolie Conversion Projects 76 03-20-2017 03:39 AM
Foot valve Bavo76 Mechanical and Drivetrains 5 11-08-2011 11:09 PM
Small cabinet heater? Heat tape? John Heating, Cooling and Appliances 5 11-04-2009 06:18 AM
Big Foot Skoolie photo, just for laughs Elliot Naess Everything Else | General Skoolie Discussions 3 03-26-2007 03:45 PM
Foot soldier bus himem777 Skoolie Conversion Projects 5 02-13-2007 06:00 AM
