Old 09-21-2013, 09:50 AM   #1
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I learn how to jump start a car today...from this blog post.
http://blog.allstate.com/plan-ahead-...umpStart-a-Car
I'm hungry!
You Gotta Let Me Fly
Old 09-21-2013, 12:34 PM   #2
wmkbailey's Avatar
Engine: 3126
Re: I learn how to jump start a car today...from this blog p
Also, if your battery is dead, you’ll need to ask someone to let you use their car to jump-start it.
???? So if your battery is not all the way dead, how do you jump start it without another car? What, do you jump start it with your own car?
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 09-21-2013, 03:57 PM   #3
frank-id's Avatar
jump start a car
There is some thinking required to jump a battery. Many folks who jump a battery do not allow the cables to stay connected untill the dead battery has enough voltage to allow the alternator to begin to refill the dead battery with more voltage. A dead battery can be thot of as a empty container. A fully charged battery is as a container full. Jumping a battery fills the container with a small amount of voltage with is used by the engine running. An alternator needs at least 12 volts to make 15 volts using just about 2 amps to make about 80 amps. A good jump for a dead battery is at least 5-10 minutes. Frank
The blog thread (post yours here) ziggy Everything Else | General Skoolie Discussions 3 11-18-2012 06:13 PM
My Blog nate1191 Everything Else | General Skoolie Discussions 3 04-14-2012 01:07 PM
Feel free to jump in here... Griff Conversion General Discussions 0 03-28-2009 01:03 AM
Top Gear: Bus Jump Steve Everything Else | General Skoolie Discussions 5 01-14-2007 05:36 PM
1987 Skoolie with DT-360 - help me learn about my first bus BlackBus Everything Else | General Skoolie Discussions 1 11-09-2006 09:51 PM
