Old 07-25-2007, 11:37 PM   #1
odyssess's Avatar
Engine: T444E 3800
I need help installing my roof vent!!!!!!
I bought a sureflo gold series roof vent for my bus, and now it seems to be much deeper than my roof. The Bus roof is about 2in. from outer to inner and the vent is about 3 3/4in. deep. How can I mount it without it looking wierd on the inside? Also I thought I could run the wiring in between the roofs, but the cross beams seem to be solid. How can I wire it without having exposed wires? Thanks for any help.
https://www.skoolie.net/gallery/v/Skooli ... Green+Bus/
Keep on Keeping on.
odyssess is offline   Reply With Quote
Old 07-25-2007, 11:56 PM   #2
eggman's Avatar
Re: I need help installing my roof vent!!!!!!
Is there a way to trim the depth off of the vertical pieces? I had to trim about 1 1/2" off of a carrier mounting plate for my roof top ac unit to get it to work. I would mount the vent on the roof with a couple of screws to hold it in place and trim the lower part (the part sticking out) to fit. Then slip the lower piece in and size it to fit and then trim it as well. Might even have to put in a piece of 1 x 2 to provide spacing for the two roof panels.
For running the wiring in the roof panels. I seriously doubt it. The ribs in my AmTrans body are pretty solid through out. What I did for the 12 volt wires was to put a couple of short walls in width from floor to ceiling and ran the wiring in them much like residential wiring. Then ran the wires up into the ceiling as it went past the roof top ac unit opening and then back out into the wall on the other side. For the 120 volt, I ran it along the base of the walls on both sides with a piece of 1" conduit running from side to side carrying the 120 volt wires.
HTH
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 07-26-2007, 12:06 AM   #3
odyssess's Avatar
Engine: T444E 3800
Thanks Eggman, but I can't trim enough off the vent to mount it flush on the roof. I'm thinking I'll use some spacing wood on the inside and paint it white. Maybe it won't look too bad. The wiring is going to be a problem. I also bought a carrier air-v and think I might have the same problems. Any other suggestions from you guys or gals is greatly appreciated!!!!!
Keep on Keeping on.
Powered roof vent question BUSBOZO Conversion General Discussions 0 07-13-2010 07:31 PM
What is this vent......... Funkpirate Conversion General Discussions 5 04-15-2010 09:46 PM
Looking for a used vent. Bus Project Conversion General Discussions 0 02-11-2010 08:25 PM
Info on installing roof top ac whoopty Conversion Tutorials and How-to's 2 05-07-2008 08:05 AM
installing a roof vent fan sqitribe Conversion General Discussions 1 03-02-2005 07:15 AM
