Old 05-30-2019, 05:10 PM   #21
Juliol, i'm in west L.A. usually. I'm mobile.
802trees is offline   Reply With Quote
Old 05-30-2019, 05:13 PM   #22
Thanks les,
The auction was 422 riverside ca.
He said they will be moving more to the bus yard soon. Would rather find something closer in So cal. Thanks.
Old 05-30-2019, 05:30 PM   #23
HazMatt's Avatar
Chassis: IH 3800, 8 window
Dang! That's near my alma mater.
Highlanders rock!
(Often attached to a chain, and hurled over a bar...)
Old 06-08-2019, 10:59 AM   #24
Rated Cap: 71
Set a max budget and stick to it! If it’s a GREAT bus, been maintained regularly, minimal to no rust, has easy bolts not rivets to work with, then maybe go $500 over budget. Once you get past your number, stop. There is a bus out there perfect for you, be patient!
rydawg3000 is offline   Reply With Quote
Old 06-08-2019, 11:55 AM   #25
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
^what he said except don't fear the rivets if you have access to a large compressor and air chisel. When I took my rivets out it was way faster than screws would have been.
Ted
Old 06-22-2019, 07:42 PM   #26
Lol, I went to a -z bus sales to see about another bus. That bus above, I was out bid on was them!
