Old 08-06-2006, 10:16 PM   #11
Coachwork: Ward Genesis
Engine: DT466/MT643
Black smoke is wasted fuel out the tailpipe...DEFINITELY something to have checked out! Drinking a quart in 100 miles would produce a blue cloud that would do a Hollywood smoke generator proud, in addition to having the back of the bus literally DRIPPING with it...I'm guessing it's leaking it. Oil pan, rear main seal, valve covers...I'd bet one or all of these are dumping it all over the place.
Jarlaxle
Old 08-07-2006, 06:10 PM   #12
Yeah if it was burning that much you would probably have some serious smoke.
The two stroke detroits have "slobber tubes" that let slobber drain from the air box. The two strokes really like to mark their territory. They tend to leak at every gasket. Sort of like my old Mitsubishi Mighty Max.
busone is offline   Reply With Quote
Old 08-08-2006, 12:51 AM   #13
No I rarely have blue smoke at all. My friend is a diesel mechanic and smelled the exhast saying it doesnt smell like there is much oil being burned.
There is no oil leakage anywhere. its like the oil is disappearing.. i dunno were gonna take a deeper look later.
ParadigmCrime is offline   Reply With Quote
Old 08-08-2006, 01:55 AM   #14
the_experience03's Avatar
If it's not going out the exhaust or on the ground, the only other place it can going is in the coolant
Old 08-08-2006, 05:54 PM   #15
lapeer20m's Avatar
i've been reading a lot of ebay adds lately scoping out a "new" tour bus. I notice many ads claim that they have a DD 71 or 92 series engine that "doesn't use any oil". whenever i read that, the credibility of the seller is diminished significantly.
Old 08-08-2006, 10:57 PM   #16
Well they say it does not use any oil. They don't mention anything about leaking oil
Old 08-13-2006, 07:28 PM   #17
Engine: DT466/MT643
I saw a Detroit 8V71 in a General tractor that used less than a gallon in 2500 miles. No leakage at all.
Jarlaxle
What Motor TheHobbits Mechanical and Drivetrains 12 10-27-2014 01:37 PM
NEED HELP with Gas Motor! AHHHHHH... timbuk Mechanical and Drivetrains 6 01-23-2010 10:39 AM
Which bus/motor would you get if you did it over? KC10Chief Mechanical and Drivetrains 36 03-03-2009 05:08 PM
Excessive Steering Wheel Play Causes? wdbowers Short-Bus Conversion Projects 1 12-24-2008 07:16 PM
Motor and trans info on a 1979 ford gas motor auto trans highvoltage21733 Conversion General Discussions 3 10-28-2005 09:31 AM
