Old 05-19-2009, 01:10 PM   #1
swinada's Avatar
Re: If someone wanted to drive this......
now that would be a camper in the size fit for my family
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 05-19-2009, 03:48 PM   #2
ezbme's Avatar
Coachwork: Thomas Transit Liner
Engine: CAT 3208 Turbo
That would be the ultimate conversion! Back roads would be tough tho...clearance issues, tight roads...
Although I have seen these doubles in the city & they have the same turning radius as a single body.
I wonder if it could be titled as an rv?
ezbme is offline   Reply With Quote
Old 05-19-2009, 09:08 PM   #3
lapeer20m's Avatar
Originally Posted by FightingDrag
think it would be reasonable to make a dog-nozed modified to pull the BACK of a diesel pusher? can they be wired together to have the same acceleration?
now that is a great idea! Dual bus engines! very redundant, and plenty of hill climbing power.....you'd need 2 rear axles i think....or perhaps you could just swap an axle from a a semi truck truck that has drive shaft inputs on the front and the back....On a tandem axle truck it would be the axle closes to the front. The drive shaft from the trans connects to the front of the axle, then a driveshaft comes off the back to feed power to the rear axle.
it's a terrible idea...but seems very appealing to me for some reason. it's completely unnecessary, but would be an oddity. The better option is just to put a more powerful engine in a bus.
Old 05-19-2009, 09:30 PM   #4
lapeer20m's Avatar
i didn't realize you meant 2 engines in a bus that hinges in the middle.......that might be more problematic, since the hinges are the weak point in those buses. Adding more hp/torque to the equation is probably more trouble than it' worth.
Old 05-20-2009, 09:05 AM   #5
push/pull configuration like a cat 621 pan scraper/earthmover?
Old 05-21-2009, 11:41 AM   #6
lapeer20m's Avatar
like this one eh? one engine in front, one in back
here is a 60 footer that just ended on ebay for $3,300
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old 05-21-2009, 01:02 PM   #7
swinada's Avatar
lapeer you could have put 2 jaccuzies in there.
Old 05-21-2009, 01:27 PM   #8
2 large jacuzzi's full of babes and then go 4 wheeling
beautiful day for a drive bansil On the Road | Travel, Trips, Camp Sites, Tailgates 10 01-02-2013 10:48 AM
How to drive down a mountain? TygerCub Everything Else | General Skoolie Discussions 15 08-07-2012 07:18 PM
RE drive trains rlohrey Mechanical and Drivetrains 4 10-19-2011 05:56 PM
How much do you drive it? (& when does diesel 'pay') nearhomeless Conversion General Discussions 1 06-01-2009 08:43 PM
Anyone drive a bus for a living? arfisher83 Everything Else | General Skoolie Discussions 3 05-16-2009 07:17 PM
