Old 02-22-2015, 02:24 PM   #1
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Injecting foam
If I put the OSB up like this, how easy would it be to inject foam insulation between it and the windows and how waterproof would that foam likely be?
Zephod_beeblebrox2 is offline   Reply With Quote
Old 02-23-2015, 11:30 PM   #2
Chassis: Genesis
The foam is destroyed by sunlight. You would need to black out the windows first. Further, there is a not insignificant amount of pressure from the expanding foam that would bow out the plywood, I would imagine. Also, you are going to want to use two part foam, if you hadn't realized already, as the spray can stuff isn't very good for large areas. As for waterproof? I couldn't say. I would expect nooks and crannies to not get properly filled, though, probably leading to rust issues.
Timelord is offline   Reply With Quote
Old 02-25-2015, 11:21 AM   #3
Engine: 190hp 5.9 Cummins
As mentioned the foam will fall apart from sunlight. A simple coat of UV stable latex paint will stop this.
The two part closed cell foam will not absorb water, but will leak at the point where it touches the metal if not sealed on the out side.
I would pull the window, skin the exterior, and do the foam as you show. Just put a sheet of plastic in front of the OSB.
The expanding two part pour foams do push hard outward, and you do need to support the glass if that's what you chose to do.
I will be using two part pour foam to build window and windshield inserts for their insinuative property's. If I'm in a extremely hot or cold climate, I can use the custom molded inserts to block the heat cold in most my windows.
The inserts will do the same as a insulated curtain, but much much better.
Old 02-25-2015, 11:30 AM   #4
Year: 1994
Engine: 466dt
Rated Cap: 59
I'm planning to paint the windows black on the inside then to glue plastic on the inside of the glass. As far as the foam goes, I'll have plenty pressure relief holes and will just trim off the foam that comes through.
