06-12-2010, 01:22 AM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Input wanted about an idea
What do you think about replacing the rear portion of the bus with a box from a box truck. Maybe something like a 24-28 ft box. It would give you height. You wouldn't have to skin the windows. You could leave the roll up door if you wanted to use it like a toy hauler. Kind of a cross between a skoolie and a toter.
06-12-2010, 07:38 AM
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Re: Input wanted about an idea
A skooter?!?!?
We few, we Band of Brothers. For he who sheds his blood with me shall be my brother.
- William Shakespeare ("King Henry V")
06-12-2010, 10:17 AM
Chassis: IHC
Engine: Dt360
I know this is sacrilege...but Just go with the box truck, remove the bus from the equation.
06-12-2010, 11:02 AM
Sounds like a lot of unnecessary work. I'm with Sean... just go with the truck (we thought of doing that too but the bus was much, much cheaper than any box truck we could buy). My basic theory is you can turn just about any structure into a space to live in... with a bit of sweat and ingenuity and some $$$.
06-12-2010, 10:03 PM
The only downside to going with a box truck is that it's tough to find one with a 30+ foot box to give you all the length. A DT466 or C-series Cummins is certainly more easily attained in one though. On the other hand, you can often get the boxes for scrap value. How about a pair of sea cans stacked on the back?
06-13-2010, 12:14 AM
Moderator
Originally Posted by Smitty
This.......
Smitty
I don't get it.
06-13-2010, 12:15 AM
Moderator
A skooter?!?!?
That's a good one.
06-13-2010, 12:24 AM
Moderator
I don't mean replace the whole body. Leave the drivers area and a few seats, then transition to the box. It would give you the added height to put bunks, shower, etc. The challenged like me, that would never do a roof raise, would be able to get height, roll up door, smooth sides. I'm just throwing it out there for discussion. I know some might not like it.
A couple of other reasons I am bringing this up. Boxes can sometimes be found for really cheap. Buses are usually cheaper than trucks. Put the two together.
06-13-2010, 08:37 AM
Unable to raise a roof.....but you could cut the body and add a box to the bus
Smitty
I'm with Smitty on this. You're looking at the same type of work for a roof raise as for mating a box to a chopped bus body.
Also, you'll always be plagued with leaks and other problems at the point where you mate the two, if for no other reason than body flex.
However, nearly anything is doable with enough time, money, and effort.
Good luck with your decision, and let us know how it goes for you.
jim
06-13-2010, 09:55 AM
Interesting.
06-13-2010, 04:15 PM
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Heck ,,,,i though of buying a dinner car with a sun dome and matting it up to my blue bird flat nose,,, ..same roof line's...
how about that ????
keith
06-13-2010, 04:40 PM
Year: 85
Coachwork: Ward
Chassis: G.M.C. 6000 series
Engine: 366 G.M.
Rated Cap: 60
A lot of work and I fore see a leak problem, seems doable but I think I'll put my money on a roof raise.But it proves that C.cal is using head for more than a hat rack. Ideas, that what its all about.
06-13-2010, 07:27 PM
I was directing that at the guys that said to just get a box truck and forget about the bus. The issue there is you lose space.
06-14-2010, 12:02 AM
Year: 1982
Coachwork: Thomas TransitLiner
Could be done - seems like a lot of work to keep from skinnin' the windows tho'.
I saw one a coupla weeks ago on the freeway that made me do a double take - guy cut off the back half of the bus and added a roll back and was carrying a pickup truck on it ... it was going the other way and when I first glanced over at it it looked like a shorty passing a tow truck.
td
